Cooper (non-S) pre cat delete O2 sensor question
Old Feb 4, 2020 | 09:46 AM
frankiev's Avatar
frankiev
I read quite a few posts about the
pre cat delete (with 2in pipe)and the one thing I havent seen mentioned is what to do about the O2 sensor . I'm assuming a bung needs to be installed ?
Also plan on gasket matching the factory header
Old Feb 4, 2020 | 11:35 AM
RockC's Avatar
RockC
You sure you want to remove the pre-cat O2 sensor?
The pre-cat sensor is what the engine controller uses to fuel the engine properly.
Old Feb 4, 2020 | 01:06 PM
frankiev's Avatar
frankiev
No ,you miss understood . I want to replace the pre cat section with a 2 1/2 pipe . I wasnt sure if I needed to keep the O2 sensor . I guess that pretty much answered my question though so thank you
Russter500
Sep 22, 2016 03:02 PM
two250
Jun 21, 2015 08:12 PM
Trickle X
Jun 9, 2006 09:11 AM
AINASUV
Jun 24, 2005 03:20 PM
