Suspension Upgraded / alternative rear camber bolts
Hi,
I have an unusual question.
Background: 2006 R53 JCW. Car has upgraded shocks and springs (Sachs and Eibach) which are non height adjustable. As a result the car runs lower than stock and therefore has more negative camber in the back than I would like.
As it is a 06 it has the adjustable camber bolts, however I don't think these will have enough adjustment.
I do not want to run adjustable camber arms as due to my local laws ...I would have to spend several hundred dollars to get them approved (
Question: does anyone know if there are any other eccentric camber bolt mechanisms, perhaps from the R56, BMW or aftermarket that would fit and offer more adjustment? (Eccentric bolt mechanisms do not require approval)
Its along shot but thought id ask just in case.
)Question: does anyone know if there are any other eccentric camber bolt mechanisms, perhaps from the R56, BMW or aftermarket that would fit and offer more adjustment? (Eccentric bolt mechanisms do not require approval)
arms...which in this case would be used to return camber back to original specs. Makes no sense
Ok...how about this.
Can you modify the stock arms into adjustable arms ?
I can think of one fairly simple (somewhat easy !) way to make the stock arms adjustable for length. Actually not at all unlike the adjustable aftermarket bars. With some thinking, maybe other solid ideas out there.
Unless the inspector is really knowledgeable, you might even be able to sneak it past them..!
Mike
Mike
R50/53 Lowering Camber Question
MCSmoonshine
Jul 18, 2012 09:42 PM
pmello
Suspension
Dec 17, 2007 07:09 AM
