How do I format a flash drive on my Mac so it will play in my car?
Old Jan 21, 2020 | 02:45 PM
TheBigNewt's Avatar
TheBigNewt
I tried Disc Utility on the Mac and I can't see how to format the USB drive to FAT32 (which I think I have to do to get it to play). It was MS DOS FAT16 and I dragged albums to it and they show up on the Mini but I get "unable to play". HELP!
Old Jan 21, 2020 | 05:56 PM
AZdsrt's Avatar
AZdsrt
Needs to be FAT32. Hook up with a friend that has a MS based computer.. been there, done that.
One more tip, create a folder called music. Put all your files there, don't create sub-folders. That way when you select random, ALL the files will play. When you first insert the drive, it will be read and the meta data will be stored in the stereo. I think it can do this for up to 5 drives.
Old Jan 22, 2020 | 07:06 AM
MINI33342's Avatar
MINI33342
Why not just play them from the phone via bluetooth?
Old Jan 22, 2020 | 01:35 PM
TheBigNewt's Avatar
TheBigNewt
I can't get enough music on my phone. I can play what I have though.
Old Jan 22, 2020 | 01:37 PM
TheBigNewt's Avatar
TheBigNewt
Create a folder on the USB drive called "music" right? Because I won't have anything on it except music from iTunes.
Old Jan 22, 2020 | 04:48 PM
AZdsrt's Avatar
AZdsrt
LOL, call it anything you want. What you don't want to do is put all your files in the root directory, as FAT32 has a file limit of 255 in the root directory. The Mini manual isn't much help with this.
A few years ago we did a cross country trip in our mini. I had my laptop with me, so I had a lot of time to play with this. At first I created a separate folder for each album, that's when I discovered the random feature would only work for the files I had in that folder. Hope I'm making sense here..
BTW, what part of AZ are you located?
Old Jan 24, 2020 | 11:31 AM
TheBigNewt's Avatar
TheBigNewt
I'm in Prescott. Got my 2 Minis in Scottsdale.
Old Jan 24, 2020 | 11:46 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Not true.
Old Jan 24, 2020 | 05:04 PM
AZdsrt's Avatar
AZdsrt
Originally Posted by Minnie.the.Moocher
Not true.
Well darn, I just looked it up. You're right, not sure why I was having problems putting a large number of files in the root directory..
Old Jan 27, 2020 | 08:43 AM
mountainhorse's Avatar
mountainhorse
Minnie.the.Moocher... Were you able to load a USB-memory stick with songs from your Mac?
Is there a practical limit to the size of mem stick you can use... I'd like to put my entire library of MP3's 512GB stick (there's 387GB MP3's on my laptop)
Old Jan 27, 2020 | 08:54 AM
Minnie.the.Moocher
Different generations of MINI so not sure what applies. I don't use the MAC anymore but when I did I was able to use several file formats, so a conversion was needed. MP3 or ACC as I recall.
I have a 128 gb stick in now but it won't read all the files. 64gb works fine. 387gb, please let me know if you get that to work, which is doubtful. I mostly just use my phone now with FLAC files and a bluetooth connection to the DSP I use.
Scypio
Navigation and Audio
Sep 23, 2019 04:03 PM
Vladi Trop
31
Jun 6, 2012 10:57 AM
ian3
May 6, 2011 09:32 AM
fishbert
Jan 28, 2011 08:46 AM
John Felix
Feb 4, 2010 05:22 PM
