Stuck in Service Mode?
Old Jan 16, 2020 | 07:15 PM
Steven Robinson's Avatar
Steven Robinson
So I recently just changed the headlight bulb in my car and now I cannot roll up or down my windows, no interior lights turn on except the map lights, hi beams don't turn on, turn signals don't work, and a bunch of other things as well probably.
It gives me the light that shows the mini on a lift in red on the tac screen.
The only things I did was disconnect the battery, replace the headlight, then reconnect the battery.
If anyone has had similar issues please tell me what you did to fix it thank you!
Old Jan 17, 2020 | 09:12 AM
Minidogger's Avatar
Minidogger
What generation is your car?
I know for Gen2, you can access the DTCs with the button on end of turn signal lever. Once there, you can clear the code. There is a how-to somewhere on this site.
Old Jan 17, 2020 | 01:48 PM
MiniToBe's Avatar
MiniToBe
if you disconnected the battery for this task, chances are the FRM module is dead. It is a common issue and you may have it covered under extended warranty. Call the dealer to see if it is cover.
Systemlord
Dec 21, 2022 05:24 PM
UncDeo
Nov 4, 2019 04:08 AM
Corona
Oct 18, 2019 09:31 AM
Frustrated mini
Sep 19, 2019 11:54 PM
