Turns over but won't start
Old Jan 15, 2020 | 08:14 AM
Rick Haynes's Avatar
Rick Haynes
Hello .I have a 2007 Mini Cooper S,. I just got it a week ago and it has been starting and running good until this morning. When attempting to start it sounds like it just about starts but does and just keeps turning. The tax shows slight movement. I only discovered this morning that I was supposed to be using 91 gas . Any ideas?
Old Jan 16, 2020 | 10:22 AM
MiniToBe's Avatar
MiniToBe
it could be anything. check compression, try quick starter fluid/spray, check spark plugs, check the high pressure fuel pump, check the fuse box for water damage specially if you have a sunroof...etc
Old Jan 17, 2020 | 10:56 AM
texasmontego's Avatar
texasmontego
Check if you’re getting spark. Is it getting fuel? Remove a spark plug and look down the port while someone tries to start it. Do that for all 4. You should see fuel spray.
kayer56
Feb 6, 2019 08:17 PM
jeffl
Oct 9, 2016 09:23 AM
z3ds
Jan 7, 2016 09:06 AM
KnightmareCS
Oct 17, 2012 09:34 AM
zeus7625
Mar 6, 2009 07:09 PM
