Coolant leak near alternator—what's most likely cause?
Old Jan 13, 2020 | 10:30 PM
jamesfacts's Avatar
jamesfacts
I noticed today that a friend's R56 (It's an S model) was alarmingly low on coolant. After poking around under the car I discovered a leak close to the passenger rear corner of the engine. I can't see too much of what's going on without disassembling the engine but I assume there are only so many components in that corner of the engine bay that can leak coolant.
What's my likeliest suspect?
Thanks!
I believe this pulley is close to the alt
Old Jan 14, 2020 | 05:31 AM
MiniToBe's Avatar
MiniToBe
There is the water pump. and behind it under the intake manifold is the water pipe that connects to the thermostat. all known areas of leaks.
check newtis.info for how to's
Old Jan 14, 2020 | 07:19 AM
Water pump or water pipe on the far side, mine leaked in the back corner for the water pump, the plastic housing cracked. Upgraded to metal and GTG.
All info here:
https://www.northamericanmotoring.co...8-no-heat.html
Old Jan 14, 2020 | 07:56 PM
jamesfacts's Avatar
jamesfacts
All info here:
Awesome, thank you! Already been through the turbo oil feed and exhaust with ECS parts
Old Jan 15, 2020 | 05:44 AM
Welcome, yep that thread shows all the parts and repairs i have done already.
dslade
May 14, 2018 04:11 PM
missinmyjeep
Mar 28, 2017 10:35 AM
blanc71
Oct 28, 2013 07:07 AM
tberg44
Oct 7, 2013 05:55 AM
scurrygirl
Jun 3, 2013 12:28 PM
