BimmerCode - code detail questions
Old Jan 12, 2020 | 04:36 AM
ZRXChris's Avatar
ZRXChris
R55 BimmerLink error codes. more detail
Well, BimmerLink is kind of like watching the movie, “The Ring” I’ve got all these error codes that haven’t yet thrown a CEL, but they could happen.
Could someone help me to understand a few of them?
2F07: DFES_DTCM.DFC_THMNPL_C - MAP THERMOSTAT, MECHANICS
so if my car isn’t running hot enough does this error point more to the water pump or thermostat?
Car Access System
2 errors
A0B8: HALLSENSOR_RAST_KS D904: K_CAN_LEITUNGSFEHLER
Sliding/Tilting Sunroof
1 error
DA04: ERROR K_CAN_LOW
I’m going to the dealer next week to hopefully get a new FRM replaced under warranty. Hoping maybe it will clear out this exterior light error. All my exterior lights work. What the hell is a “limiting light”?
I also get this low beam error but all my headlights work and I don’t have fog lights. The running light works but when I got the car about 2 months ago I fixed an error for the left side by replacing the left rear light assembly.
Driver's Side Footwell Module
3 errors
A8AC: LIMITING LIGHT LEFT DEFECTIVE A8C1: REAR RUNNING LIGHT LEFT DEFECTIVE
A8AF: FOG LIGHT RIGHT, E90 M3: DAYTIME RUNNING LIGHT RIGHT DEFECTIVE, PL3 FROM 07/14 AND (SA5A1 OR SA896): BRAKE LIGHT RIGHT DEFECTIVE
Gas gauge seems to work and my sunroof opens closes.
1 error
Instrument Cluster
1 error
9319: ERROR SIGNAL TANK RAW_DATA_FILLING_LEVEL_LEFT
Is my stereo going to die?
Amplifier
1 error
D6C4: BUS WIRING INVALID
If Bimmerlink shows these errors but when you click on the details and it says it’s not generating a code does that mean they’re about to fail but just haven’t yet? Again this damn app is like watching “The Ring” movie.
I love this car, but mostly while it’s standing still...
Old Jan 14, 2020 | 07:08 AM
MiniToBe's Avatar
MiniToBe
some codes pop up as a consequence of another thing. for example, if the FRM is dying, it will surely effect other modules through the Can or K bus. Similarly, when the battery starts to flat out, multiple codes pop. Since you have a sunroof, check the fuse box on the right side for water leaks and such. clear the codes and see what pops back up.
jcb-memphis
Jul 10, 2015 09:12 PM
dnnweller
Mar 8, 2010 06:49 PM
Carve906
Mid-Ohio Motoring Club
May 12, 2008 08:29 PM
Mustang7302
Oct 17, 2007 03:39 PM
umberto
Aug 29, 2006 08:47 AM
