R50/53 Replacing motor with auto tranny
Old Jan 10, 2020 | 05:30 PM
maddog2020's Avatar
maddog2020
I posted a few weeks back about my daughter's mini with low compression. I've been working on selling it, but am starting to have second thoughts and am thinking about buying a used motor on ebay - there seem to be some decent fairly low mileage motors to be had for around $1500. I'd like to do the swap myself, but am curious as to how hard it is. I've done my share of work on many cars over the years, including engine swaps, but never on a car this complex, or with an auto. Is there any major different in procedure with the auto? Anything to be particularly concerned about? From what I can tell, there is no different in the motor itself.
Ian
Old Jan 10, 2020 | 05:59 PM
BlwnAway's Avatar
BlwnAway
Correct, no difference in the motor itself between manual and auto, and since it's a straight swap, no problems with the correct mounts or sensors.
It's a lot less scary once you start to get into it, just Bag-N-Tag everything, with lots of pictures and wiring tags with tape and it's actually petty straight forward.
Just remember, one bit at a time, makes it a lot less confusing and stressful.
And pick up a Bentley Manual, it's indispensable for jobs like this.
Old Jan 10, 2020 | 06:05 PM
maddog2020's Avatar
maddog2020
The swap videos I seen remove the engine and transmission as a single unit, so I guess I would have to remove the transmission from the old engine and put it back on the new one. My main challenge is that I don't have the garage space to do the job indoors, so would have to do it outside. That would mean doing it in a single weekend in my driveway. I think we might just have to part ways with the car, sad.
Ian
Old Jan 11, 2020 | 08:43 AM
Racingguy04's Avatar
Racingguy04
You might look into a local community garage. Sometimes you can find a garage that lets you rent a bay and use their lift (and sometimes tools) to work on your car. If you have a buddy to help and a good garage and lift, I feel like you could do that job in a weekend (and maybe call in sick on monday to rest)
Old Jan 12, 2020 | 06:20 PM
jk6672's Avatar
jk6672
Nothing wrong with leaving it in the driveway to work on. I did it, I went a little overboard and started replacing or powered coating everything so it was in the driveway a little longer. I just covered to with a car cover.
Old Jan 13, 2020 | 10:25 AM
ssoliman's Avatar
ssoliman
I do my work in the driveway also...use a car cover
Dustin Hoffman
Feb 12, 2017 05:37 PM
MachinegunMountain
Nov 8, 2014 12:49 PM
Sledge
Feb 24, 2013 07:46 AM
5810
Feb 17, 2011 08:32 PM
TheBluePotato
Classic Mini Talk
Nov 24, 2006 09:46 PM
