R56 Trunk lock warning light
Old Jan 9, 2020 | 05:13 AM
fcaceres's Avatar
fcaceres
Anyone know where is locate the trunk lock sensor? open trunk warning light show always when I stop and move the car. It’s make me nutz
Old Jan 9, 2020 | 05:26 AM
MiniToBe's Avatar
MiniToBe
it is built in the actuator. could the trunk be open? sometimes the plastic/rubber cover of the button breaks or the water gets from the plate light and cause the handle to self trigger.
Old Jan 9, 2020 | 05:39 AM
fcaceres's Avatar
fcaceres
MiniToBe The trunk open and Close normally, the only problem is when Stop/move the car, warning light show. It could be something into the junction box ? or the wiring sensor is cut in somewhere?
Old Jan 9, 2020 | 05:53 AM
MiniToBe's Avatar
MiniToBe
https://www.newtis.info/tisv2/a/en/r...button/cjbLDL3
https://www.newtis.info/tisv2/a/en/r...tlputs/cjqo8IJ
The middle diagram shows the boot lock and on the second link, it is the last connection going to the fuse box.
When the light comes up, can you verify the lid is closed. bush on it to feel for space. Mine used to do that. Also, check if the lock itself actually closes all the way. open the hatch, and use a screw driver to push on the latch as if the hatch is closed. then drive to see if the light comes again.
Old Jan 9, 2020 | 06:39 AM
fcaceres's Avatar
fcaceres
I Will try. When finish I will send a feedback
Lombomini2009
Feb 12, 2014 04:16 PM
flee
12
Sep 19, 2013 10:30 PM
cooperchan
Feb 23, 2008 02:22 PM
peekinde
Jul 20, 2007 01:15 PM
Aviators
Feb 15, 2006 03:58 PM
