Check Those Spare Tires!
Old Jan 5, 2020 | 01:50 PM
Lancaster's Avatar
Lancaster
... Especially if weather is cold for you this time of year. I dropped my Cooper’s spare yesterday. It was totally deflated and the rim was covered in rust. We use a lot of salt this time of year, every year. Sadly, the rust was at the most critical welded points and around the valve stem. The really big, flaking deep rust, not just a little surface stuff. I took off the rust with the wire wheel, spayed on rust converter and then a good top coat of Rustoleum. A few more years and I do not think it would have been roadworthy even if it could hold air. I also disconnected the additional inflation line as I suspect it was the cause of the deflation.
It was also a good time to remind my son of the importance of knowing what to do before you are stuck on the side of the road.
Old Jan 5, 2020 | 02:12 PM
cristo's Avatar
cristo
Alliance Member
Also, even if the wheel, valve, and tire
look OK, strongly consider replacing
the tire when it’s 6-8 years old by the
DOT date code.
New valve, too.
The rubber doesn’t last forever.
TireRack sells replacement tires for
compact spare wheels.
Just search by tire size.
Old Jan 6, 2020 | 02:10 PM
Yep, mine is rusted on my R52 and the tire is all cracked, thanks for the Ohio brine they spray on the road. I have to get a new one. I cleaned it, removed it, waxed, and treated the tires but after a while it gets pretty bad as it seems to be a big collector on the underside and holds the salt.
We carry kits now..
Also the stem extension is stuck rusted on the stem, i greased it and after a while it rusted shut. https://www.ecstuning.com/b-genuine-...106783425~oem/
https://www.ecstuning.com/b-assemble...1150916411570/
Old Jan 7, 2020 | 06:18 AM
Andy_S's Avatar
Andy_S
Where do you store a spare wheel on an R52 that it's exposed to the road salt?
Old Jan 7, 2020 | 06:40 AM
Its factory on the underside for the R50 and R52 Cooper.
russmini
Apr 18, 2014 02:37 AM
nansumner
Jun 28, 2013 08:03 AM
jeffm5150
Classic Mini Talk
Mar 23, 2009 08:30 PM
mrgentleminh
21
Mar 28, 2008 08:29 PM
mininh
Tires, Wheels, & Brakes
Mar 3, 2005 11:38 PM
