R56 Electrical Issue
Old Jan 3, 2020 | 08:02 AM
fcaceres's Avatar
fcaceres
Electrical Issue
Hello,
I have an electrical issue when live the car 1 or 2 hour, also in the morning. I want to know if is the FRM, CAS or JBE module?
here the video:
Old Jan 3, 2020 | 08:49 AM
-T.'s Avatar
-T.
I'm new to the Mini scene, but the crank over sounded a bit slow. I'm wondering if you may just need a new battery? I'm sure, like most new cars, all sorts of strange things can happen when the voltage gets even a little lower than the computers are expecting to see. If the car runs for awhile, do the gauges begin working again? Running the engine a bit, may get the battery charged enough for things to get back to 'normal' Since we don't have any gauges to get information from, perhaps put a voltage tester on the battery after the car has sat from awhile and see if it is down below 12v.
Good luck.
Old Jan 3, 2020 | 09:18 AM
fcaceres's Avatar
fcaceres
Good luck.
The battery is new, I bought it 2 weeks ago. Then drive for a while the gauges work again without problem but only disappears when I turn off and restart the engine. Everything works fine after driving for a while after turning the engine off and on.
Could be de CAS, FRM or JBE module?
Old Jan 3, 2020 | 09:36 AM
MiniToBe's Avatar
MiniToBe
JBE...if you have a sunroof, water might've gotten there and cause a short or damage.
Old Jan 3, 2020 | 09:52 AM
-T.'s Avatar
-T.
I'm probably thinking too basically, but is the alternator doing it's job? Are you showing better than 14v. or so with engine running? I'm just thinking about the basics right now. I haven't had mine long enough to deal with these modules yet... In due time, I am sure I will... lol
Old Jan 3, 2020 | 11:05 AM
fcaceres's Avatar
fcaceres
Yes, i Have sunroof. but I dont see any water or puddle. I clean all de jbe module also.
Old Jan 3, 2020 | 11:06 AM
fcaceres's Avatar
fcaceres
Yes, the alternador voltage is 14v.
Charley Cartee
Jan 12, 2024 05:44 AM
Michael Sanchez
Apr 8, 2019 01:28 PM
Filmy
Sep 25, 2011 04:03 PM
erickvonzipper
Apr 9, 2010 03:03 PM
cootie
Classic Mini Talk
14
Feb 17, 2009 07:15 AM
