R50/53 Anyone with Detroit Speed Bypass Valve?
Old Dec 31, 2019 | 09:58 AM
alconk's Avatar
alconk
I bought this from reading about it and since it’s been installed I get a yo yo effect in the mid boost range at part throttle. Drives me nuts so I switched it back and the effect was gone. So just recently I reinstalled it and yep the yo yo is back. Anybody else running these have that? Is it normal for those to do that?
Old Dec 31, 2019 | 11:25 AM
kkcshipp's Avatar
kkcshipp
Yes, I have the exact same thing since installation. When I do my SC service it will come off! The seller will claim we have a vacuum leak. Hogwash!
Old Dec 31, 2019 | 12:18 PM
alconk's Avatar
alconk
yep I will be putting the stick one back on as well.
Old Dec 31, 2019 | 12:42 PM
1qwkmini's Avatar
1qwkmini
Have you ever check it for a vacuum leak??...maybe you should before calling out the vendor.
Bet you dollars to donuts that you have one!!!!
Have run one for 4 years, no issues...except when I have vacuum issues.
These things are notorious for leaks, especially at the charge pipe/SC gasket.
Old Dec 31, 2019 | 04:22 PM
kkcshipp's Avatar
kkcshipp
then I will take your money. I had a smoke test done by a local Mini Tech who was the shop foreman at Mini of Louisville. No leaks, not “calling out the vendor.” Just stating facts.
QUOTE=1qwkmini;4511850]Have you ever check it for a vacuum leak??...maybe you should before calling out the vendor.
These things are notorious for leaks, especially at the charge pipe/SC gasket.[/QUOTE]
Old Dec 31, 2019 | 05:54 PM
jk6672's Avatar
jk6672
I have one and I haven't noticed anything weird.
Old Dec 31, 2019 | 07:59 PM
alconk's Avatar
alconk
I wasn’t or intentionally calling out the vendor I just wanted to know if my issue was normal. I just think it’s weird that that stock one has no yo yo affect and when it was switched it did.
Old Jan 1, 2020 | 01:36 PM
Husky44's Avatar
Husky44
Add me to the list of users with no issues. I've been running mine for several months without a problem. I installed it after research hing solutions to the major throttle lag I was experiencing, which went away with the new valve.
Old Jan 3, 2020 | 10:21 AM
IQRaceworks's Avatar
IQRaceworks
I think that to a certain extent, no matter what you do.....with a vacuum controlled bypass valve, you are going to get some yo-yo affect depending on engine load, rpm, throttle position, boost, etc, etc....
My Detroit BPV had less yo-yo than the stock BPV, but it's still got some. It's just the nature of the beast.
Trippy
May 20, 2025 03:08 AM
banzairx7
Apr 16, 2012 09:08 AM
herbie hind
Mar 23, 2009 01:31 PM
ViVi^BoY
Nov 3, 2007 10:46 PM
regalic
Mar 17, 2005 04:54 AM
