Drivetrain Boost blues
Old Mar 22, 2009 | 05:47 PM
herbie hind's Avatar
herbie hind
Boost blues
can anyone with a big valve head chime in and tell me if 13 lbs. boost is okay ? i was at 10 lbs. but the bypass valve was waaaay off . big daylight. after adjusting the bp i'm at 13lbs. 15% pulley and half a hole showing with no noticeable slip . vacuum is at 18 at idle . chopping throttle produces 22 in. so at 93000 mls maybe it.s grey hair is showing ?
Old Mar 22, 2009 | 08:11 PM
Fatherdeth's Avatar
Fatherdeth
That's weird. I'm pushing 16 psi with a DT bypass valve, 15% s/c pulley and 44K on the clock. At idle, I believe my vacuum is at 20 and at 25 while cruising. It could be your bypass valve and your mileage. I originally pushed 15 psi before the DT bypass valve. Even if the bypass valve isn't completely bad, it wouldn't hurt to change it. While you are changing it, clean the throttle body as you have to remove it anyway. Your boost might not be bad considering your mods, but I'm not too keen on big valve heads. How's your acceleration and response?
Old Mar 22, 2009 | 09:22 PM
batrugger's Avatar
batrugger
your boost pressure gauge will read lower with the big valve head. It is okay. We only hit 14 with a 17%.
Old Mar 23, 2009 | 06:53 AM
Mike S's Avatar
Mike S
I wish I even got that high, I'm getting around 10 psi with a 17% and DTBPV. Then again I am 4200ft above sea level
Old Mar 23, 2009 | 10:40 AM
batrugger's Avatar
batrugger
I'm close to that at 3200
Old Mar 23, 2009 | 11:00 AM
Fatherdeth's Avatar
Fatherdeth
Why are you guys complaining? You all have big heads (no pun intended). You're laying down more hp than me. LOL!!!
Old Mar 23, 2009 | 11:06 AM
batrugger's Avatar
batrugger
LOL too. Acceleration and throttle response are excellent. a lot snappier than my Jetta GLI
Old Mar 23, 2009 | 01:31 PM
herbie hind
thx for the responses. i have a detroit on the shelf, i didnt like it . too hammer like if i remember right . yeah the vac could maybe be higher it seems . i'll def. get a new bp valve . cleaned tb also . time to check compression again . .020 over soon . lol . could be worse . it's back to rippin tires loose though .
gar56
Nov 15, 2016 06:41 AM
minimofo
Dec 26, 2015 12:03 PM
jeri534
Nov 6, 2015 01:40 PM
EVMini
Sep 28, 2015 10:20 AM
