R50/53 Yellow light
Old Dec 18, 2019 | 05:00 PM
jk6672's Avatar
jk6672
Yellow light
I finally started my R53 today after about a years time of taking it apart and putting it back together. It runs really nice. Smells nasty though, and I’m sure it’s the cerakoted headers heating up for the first time. It started ruff, but that was my fault. I forgot to plug the electronic throttle control. Plugged it in and cleared the codes before restarting, but the yellow light won’t go away.
I changed the exhaust, header back, Detroit tuned bypass valve, air ddmworks air box, plugs, 15% SC pulley, 2% OD pulley. Could no brake pad wear sensors cause this? I did install a Wilwood brake kit, and there are no wear sensors
Old Dec 18, 2019 | 05:06 PM
Canyon_Mini's Avatar
Canyon_Mini
Not having a sensor will cause the light to come on.
Old Dec 18, 2019 | 06:30 PM
BlwnAway's Avatar
BlwnAway
Correct, if you're not using the sensors, cut them and connect the wires together
Old Dec 19, 2019 | 11:11 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
Take the old sensor and cut the wires about 2 inches or so out, strip both ends and twist the wires together. Wrap in e tape. Plug it in and turn the key to the first click till the light goes off. Your good to go!
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Dec 19, 2019 | 12:24 PM
jk6672's Avatar
jk6672
thanks, that’s the plan
Old Dec 21, 2019 | 08:53 AM
ghostwrench's Avatar
ghostwrench
My bulb eventually burned out, so there's that option too.
AND4848
14
Oct 15, 2013 07:03 PM
[insert name here]
Tires, Wheels, & Brakes
12
Apr 20, 2012 06:28 AM
Kennedy
Sep 2, 2011 03:53 PM
jazztronikk
May 25, 2010 06:37 AM
SKL
Oct 28, 2007 05:58 PM
