R50/53 Horn issues
Old Dec 7, 2019 | 09:31 AM
ewgoforth's Avatar
ewgoforth
Horn issues
Hi,
The horn in my 2003 R53 worked intermittently then stopped working altogether. I'm trying to fix it.
I basically leaped to the conclusion that my clockspring was bad and bought a used clockspring off ebay and it does the same thing. The horn doesn't work but all the other functions seem to work: cruise control, stereo volume, etc. I thought I heard a faint toot when I pressed the button.
Has anyone heard of the horn buttons themselves failing in R53s? As I recall one horn button seemed to stop working before the other. Is there any good way to test the button?
I started looking at testing the horns themselves but it looked like I'd have to remove the whole front bumper.
Old Dec 7, 2019 | 10:36 AM
KevinR's Avatar
KevinR
When mine quit working, I just assumed the horns were bad and replaced them with Hella Supertones. Problem solved.
Old Dec 7, 2019 | 10:50 AM
ewgoforth's Avatar
ewgoforth
Here's a picture of a non multi function clockspring. The green and black wires are for the airbag, so the other 4 pin connector must be for the horn.
I believe if I remove and disconnect the airbag like I did before and then disconnect this cable from its socket that I should see continuity on its wires when I press the horn button. Also if I reconnect the battery and jumper some combination of pins in this socket I should hear something from the horn.
Old Dec 7, 2019 | 10:54 AM
KevinR's Avatar
KevinR
Frankly, that seems like a lot more work than pulling the bumper cover and testing the individual horns.
Old Dec 7, 2019 | 12:52 PM
ewgoforth's Avatar
ewgoforth
I removed the bumper and horns and tried connecting each to the battery terminals multiple times using jumper wires with a alligator clips. The pins inside are so small it's hard to be sure that you are making good contact, but I did it enough times I'm pretty sure I would have done it right at least once. I didn't hear anything.
I also stuck some wires in the horn socket and had my daughter push the horn button and I didn't see any voltage on my multimeter so it looks like I have problems on both ends.
Old Dec 7, 2019 | 02:29 PM
ewgoforth's Avatar
ewgoforth
I removed the sockets from the horns which exposed a larger terminal underneath. I touched the terminals to the battery and got a brief toot out of one but bit the other. I've ordered some new horns.
Old Jan 21, 2020 | 06:42 PM
ewgoforth's Avatar
ewgoforth
That didn't fix it but changing my horn buttons did.
DaGriz
Feb 25, 2017 05:26 AM
BernieCoop
Jan 20, 2013 03:17 PM
waltph
Sep 7, 2011 08:47 PM
AdmiralKit
Nov 12, 2009 05:17 AM
dpilgrim
May 13, 2003 12:12 PM
