R55 R55 Low speed fan issue
Old Dec 5, 2019 | 07:19 AM
pecormd's Avatar
pecormd
Hello guys, I have read numerous threads about Low speed fan not working. First I turn on the ignition and turn on the AC full blast low speed fan will not come on. I can remove the temp sensor plug and the high speed fan will come on. I tried switching relays while fan was running. I pull the relay and the fan stops switch it with the low speed relay comes back on so seems both relays are interchangeable and working. i did a continuity test from the fan to the relays terminals in the fuse box got a tone on all 3 wires. I have 12V to the fuse box. I changed the fan assembly out same issue not working on low speed. i even changed out the temp sensor no change. I'm stumped any ideas checked all fuses as well.
Old Nov 18, 2023 | 10:00 AM
rollinkarr's Avatar
rollinkarr
Did you get a solution?
I’m having the same issue, did you get yours fixed?
Old Nov 20, 2023 | 09:07 AM
Touring1914's Avatar
Touring1914
Pcormd,
Your post is most timely, My mini has the high fan on for about 10 minutes or so after I drive. The coolant level is fine and I don't see any leaks.
My main concern is, can I drive the car while with out hurting it, while I am trying to diagnose the issue?
Steve
trippyloaf
Jun 27, 2020 06:31 PM
Mini33073
Aug 18, 2019 09:34 AM
Acurtis
Dec 30, 2018 03:25 PM
majestic
Oct 18, 2014 02:13 PM
majestic
Oct 18, 2014 02:12 PM
