R56 R56 Starting problem
Old Dec 1, 2019 | 12:08 PM
crpagan's Avatar
crpagan
So I am in the process of buying my manager's 2007 Mini Cooper S. He said it needed a starter. When trying to start it just would click but not turn over. So we push started it. I drove it to a friends house. It drove fine. I ordered a new starter and put it in today. When i hit the button to start it the motor turns on then. Then it turns off and the starter continues to turn the motor over. I hit the button to stop it and it doesn't. I even take the key out and it continues to turn over. It only stops when I disconnect the battery. I even tried to connect a OBD scanner to see whats going on and it wouldn't connect. Is there something else wrong? I called the previous owner (my manager) and asked him if it was doing that and thats why the starter finally went out. He said no. Not sure what it can be. Anyone have any ideas?
Old Dec 1, 2019 | 01:00 PM
MiniToBe's Avatar
MiniToBe
Based on the wiring diagram, the signal is directly coming from the CAS, Car Access System.
https://www.newtis.info/tisv2/a/en/r...rting/CkXzalzD
Old Dec 1, 2019 | 01:34 PM
crpagan's Avatar
crpagan
So does that mean i have to replace the CAS module?
Old Dec 1, 2019 | 02:04 PM
MiniToBe's Avatar
MiniToBe
There is a chance BUT you need high level diagnostics to make sure. ISTAD is one powerful sw that is a must. Or, if you're near someone who has it, they could run through the sw. Also, inspect the fuse box behind the passenger kick panel for water leaks if the car has a sunroof.
Old Dec 1, 2019 | 02:27 PM
crpagan's Avatar
crpagan
Ok, I'll have to see if someone local has that. In the mean time I'll look behind the fusebox. It does have a sunroof.
Colin Schlagel
Sep 20, 2017 06:52 AM
ShadyCoop
Apr 6, 2016 02:51 PM
omniscott
Electrical
Oct 12, 2010 12:22 PM
Snow2pwc
Classic Mini Talk
May 21, 2010 04:48 AM
r56mini
Off-Topic :: Autos
Dec 20, 2007 12:37 PM
