R50/53 Brake bleeding 2005 mcs r53
Old Nov 25, 2019 | 01:56 PM
ssoliman's Avatar
ssoliman
Gents, quick question, when doing a standard brake bleeding, is inpa (or other) needed to actuate the abs pump?
Or will standard presure bleeding suffice?
going to try and get it done tomorrow but I don’t have inpa working yet for the mini
Old Nov 25, 2019 | 07:08 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
NO you don't need to activate the ABS to bleed the brakes. You only need to activate it if you are replacing the ABS unit itself
Old Nov 25, 2019 | 08:20 PM
ssoliman's Avatar
ssoliman
Many thanks, sir. Was not sure. First time bleeding this system on the mini
Old Nov 25, 2019 | 10:19 PM
RB-MINI's Avatar
RB-MINI
Do you have to worry about the old fluid in the pump when changing the brake fluid, or is the amount not significant enough??
Old Nov 26, 2019 | 11:24 AM
WayMotorWorks
Vendor
with the car off and ABS not active the valves are in a neutral position. So when you bleed the brakes it flows through the ABS. Sure there is still some in their that you won't get every drop out, but not any to be concerned with. Hell even on my race car I just do a normal bleed and don't activate the pump to bleed the brakes, so for a street car it's more than fine.
Old Nov 26, 2019 | 07:23 PM
OCR's Avatar
OCR
Incorrect. You DO...need to activate the ABS to get ALL of the old fluid out.. Drive it a few miles, then check the fluid color...it'll be dark if you DON'T flush both sides of the system.
Been their..!
Simple...just read the manual..!
Mike
MSLGHT
Jul 16, 2018 05:19 AM
tragedybysyntax
15
Feb 3, 2015 07:02 AM
Bajanmini
Jan 28, 2010 08:58 AM
DeepFriedDuck
Jul 30, 2005 12:00 PM
firenewt
Tires, Wheels, & Brakes
Jun 24, 2004 07:33 AM
