R50/53 Can you run with no belt
Old Nov 22, 2019 | 02:13 PM
theDonVon's Avatar
theDonVon
Can you run your r53 with no belt to try in locate a pulley or sc issue??
Old Nov 22, 2019 | 02:21 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
No. You water pump is hooked to supercharger. Will over heat.
Old Nov 22, 2019 | 02:37 PM
theDonVon's Avatar
theDonVon
Yes I know that . But can you run it for like 30-45 seconds just to see if it's your supercharger making noise or just a pulley
Old Nov 22, 2019 | 03:56 PM
Altecfenix's Avatar
Altecfenix
For a short time yes. Did it a few weeks ago on mine.
Old Nov 23, 2019 | 05:33 PM
KevinR's Avatar
KevinR
Yes. I did just that to get the car on a tow dolly when the crank pulley/harmonic balancer self-destructed.
Old Nov 25, 2019 | 07:10 AM
lotter1's Avatar
lotter1
Like above, Yes you can. I had to move mine when the alternator seized and did so with out the belt.
Make sure you have a good charge on you battery as the car will run off of it seeing as the alternator will not be supplying the juice
nshannon29
Oct 7, 2015 05:57 AM
c w
Sep 5, 2013 08:07 PM
imncrxtc
Oct 17, 2012 06:48 AM
Denisk@
Jul 9, 2012 09:08 PM
nelz886
Jun 2, 2010 10:27 PM
