Suspension Rear Sway Bar Opinions (2013 JCW)
Hey all, Looking to upgrade the rear sway bar on my 2013 R56 JCW.
It looks like the JCW has a 18.5mm bar already, so I figured I'd jump to a 22mm instead of a 19mm, so I was wondering if anyone had opinions on...
NM Adjustable 22mm Rear Sway Bar
H&R Adjustable 22mm Rear Sway Bar
H-Sport Competition 25.5mm Rear Sway Bar
I daily drive and autox 50/50 the mini and my 2015 BMW M4, so it does need to be somewhat practical for the road. Currently I'm leaning towards the NM as it looks like a more premium product and has 3 levels of adjustability over the H&R's 2 levels.
On the flip side, I like that the H&R doesn't need lubrication. I don't have much to say about the H-Sport as I'm not sure what additional pros/cons it's bringing to the table.
Should I still be considering the 19mm or will is see little to no benefit from the .5mm upgrade?
Thanks!
Thanks!
https://www.iemotorsport.com/product...r-r53-r56-r58/
Ireland Engineering. I've had this on my '13 R56S for a couple of years now. It's daily-driven and seen some track time. The bar is a 22mm hollow bar with three adjustment points, It is stiff enough to rotate the rear when you really throw it but stable for daily use. It includes adjustable end-links (E30 M3) and urethane bushings. In my opinion, it is a steal. I also have IE Motorsport adjustable rear control arms and adjustable camber plates. I have found all of their products to be high quality and durable. If you search this forum you'll find a few dissatisfied customers from many years ago. My experience with Ireland Engineering has been nothing but good.
The H-Sport is a hollow bar so it’s
about the same as a 22mm solid
bar but about 1/2 the weight.
I have one on my JCW R55 and I
highly recommend it.
It’s currently set on soft but may
go up to the medium setting when
winter is over and the sticky
summer tires go back on.
I went with NM engineering sway bar. Difference is amazing!
One of my first mods was the Alta 22mm bar. The clearance is so tight on my car that I'm sure a 25mm hollow bar would hit the body. There's a picture somewhere on NAM where somebody had installed the H-sport 25mm bar and the rubbing on the body wore a hole in it. Every car is a little different and there are a lot of people happy with the H-sport 25mm so it obviously works for most people.
qwertmonkey
Suspension
Jan 8, 2007 09:04 PM
MartyR
Suspension
Sep 27, 2004 03:07 PM
