R50/53 Slight bog on idle time to time...
Old Nov 12, 2019 | 12:07 AM
Rah's Avatar
Rah
Hi everyone,
Since i picked up the car about 4 month now, nothing went wrong with the car and i did a bunch of maintenance and upgrade on the car, including the supercharger maintenance as well as finding out why the loss of power (simple rubber line feeding into the intake unplugged), oil change, water pump, coolant flush etc, etc...
One thing i was not able to resolve is a low idle (around 500 RPM or so) at stop time to time, maybe once or twice a day on a full day use, and goes away with a quick dab or the accelerator. I did change the plugs and the wires as well just as an FYI, but it was doing it prior to the replacement as well.
Any ideas or help would be appreciated.
Old Nov 12, 2019 | 07:05 AM
NomadMac's Avatar
NomadMac
Ditto.
My idle gets lumpy at a long light even after new plugs, Demon coil and wires.
Injectors?
Old Nov 12, 2019 | 07:00 PM
Rah's Avatar
Rah
Originally Posted by NomadMac
Ditto.
Injectors?
Ok didn't think of that possibility i guess. By lumpy you mean down a bit? I wonder if a cleanout of the injectors would help or should i look into replacing possibly if that was the case. Thanks for the input!
Old Nov 12, 2019 | 08:52 PM
NomadMac's Avatar
NomadMac
It gets low and variable, inconsistent, almost like it's going to die but never does.
Blip the throttle and it comes back up.
I've run some Techron through it but it doesn't seem to make a difference.
Old Nov 13, 2019 | 04:11 AM
adriancl's Avatar
adriancl
Maybe is enough to remove throttle body, clean it,mount it back ,do throttle adapt and test the car.
Colin Schlagel
Sep 1, 2017 08:18 AM
johnsansone
Classic Mini Talk
May 19, 2016 01:58 PM
exocet
Oct 16, 2013 10:01 AM
USMarineMINI
Jun 9, 2011 07:12 AM
chawness
Jan 13, 2010 03:22 PM
