Drivetrain Service Position and Removing Subframe...
Old Nov 7, 2019 | 06:02 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
In preparing for my clutch replacement, looks like there are two steps I need to perform: place front end into service position, and remove front subframe.
Further research shows that placing the front end into service position relies on the front subframe for support... As such, how do I then remove the subframe? Looks like there are a couple of "special tools" used by Mini for such a condition:
https://www.newtis.info/tisv2/a/en/r...ntrol/JkNVj9g9
Does anyone have any information on these special tools? Or have any insight into my conundrum?
Old Nov 7, 2019 | 08:04 AM
Kupona's Avatar
Kupona
Hope you adding goodies to the subframe while you have that p.o.s out.
Old Nov 7, 2019 | 08:10 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
My plan is for clutch, flywheel, all seals, LSD, poly control arm bushings, and MAYBE a larger front sway bar. Haven't made the decision on the sway bar yet... If I don't do the sway bar, I'm going to at least add the poly sway bar bushings.
Old Nov 8, 2019 | 04:20 PM
thebombardier's Avatar
thebombardier
I put jackstands under the stock jack points.
Old Nov 8, 2019 | 11:21 PM
Scudder44's Avatar
Scudder44
You really have to dismantle the front end, not just service position, you take the front tubes off the subframe after removing the bumper, support and grill. A trolley jack is handy for supporting the subframe and moving it, it is a heavy piece.
Old Nov 9, 2019 | 04:05 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
The special tools I have linked above look to allow NOT to have to dismantle the whole front end. I will if I have to, but if I can hold of the special tools, looks like I might not have to.
BucksCountyR57
Mar 1, 2018 07:21 AM
Pramuk
Suspension
Nov 16, 2017 07:05 AM
tazio
Suspension
11
Nov 12, 2017 04:39 AM
bonusbulldog
Suspension
Jan 22, 2010 09:35 AM
Hop
Suspension
Aug 26, 2007 01:19 PM
