R56 HELP! Hood is different?? R56 07-10 11-14
Old Nov 3, 2019 | 07:05 AM
10R56's Avatar
10R56
I'm new to the Forum and a newbie to the R56. I own a 2010 Mini Cooper base hardtop/hatchback with a build date of 5/10. My hood is damaged and needs to be replaced. If you look up a hood on car-part.com (which links you to salvage yards nationwide) you'll notice it groups the 07-10 hood together and the 11-14 hood together. Some people say the 07-14 hood is the same. I can get a great deal on a new old stock OEM hood part number 41617318364. Seller says it fits 07-14. If I google that part number, general information is 11-14 or from build date of 8/10 (mine was built 5/10). I always thought the second gen base hardtop/hatchback BODY was the same from 07 to 14. I'm confused! Anyone know the differences in base hoods from 07-14? PLEASE HELP!
Old Nov 3, 2019 | 07:12 AM
mildensteve's Avatar
mildensteve
Don't know the differences but RealOEM https://www.realoem.com/bmw/enUS/partxref?q=41617318364 has that part number application as:
Part 41617318364 was found on the following vehicles:Highly recommend the RealOEM site. Has helped me innumerable times.
Old Nov 3, 2019 | 07:13 AM
Scudder44's Avatar
Scudder44
Your part number is incorrect, see the clip, it is the same part all through the build history. This is from Realoem. Have a look yourself but I selected R56, 05/10.
Cheers
Old Nov 3, 2019 | 07:31 AM
10R56's Avatar
10R56
Cheers
I can get a great deal on that part number. Just trying to figure out what's different between my factory hood on my 2010 Mini Cooper with a 05/10 build date and this new old stock OEM hood that for 08/10 and newer? I thought the 07-14 Mini Cooper base R56 hardtop/hatchback had the same body over those years?
Old Nov 3, 2019 | 07:37 AM
Scudder44's Avatar
Scudder44
The August 2010 build is LCI, read this article and you will find the hood/bonnet changed. https://www.allmagautoparts.com/blog...-changes-guide
Old Nov 3, 2019 | 08:14 AM
10R56's Avatar
10R56
I knew they made changes to the engines (base and S) in 2011 (08/10) but wasn't aware of the "LCI" or "Phase II" and all the other changes associated with it. That really helps out, THANK YOU!
sergrod
R55 :: Clubman Talk (2008+)
May 31, 2018 04:55 PM
minimike74
May 6, 2018 11:36 AM
kirin555
Apr 29, 2017 10:43 AM
Luilly
Cooper (non S)
Jan 31, 2016 06:38 PM
