R50/53 No crank after replacing damper
Old Nov 2, 2019 | 09:00 AM
r53-06m6's Avatar
r53-06m6
I just replaced my idler, tensioner, drive belt, and damper with a solid crank pulley.
Car still ran before the work but was throwing a code before I started....forgot which but I will try to find it. Idler and tensioner were both bad and car limped home.
Sounded like the valves and pistons hitting each other when started. No codes returned
Hunting desperately for a how to on doing a compression test on an r53.
Assuming stop fuel supply and stop spark?
Any ideas?
No codes being thrown now.
Old Nov 2, 2019 | 10:07 AM
r53-06m6's Avatar
r53-06m6
Started up. Pulled the plugs and cleaned up. Maybe they fouled. Crap like this gives me bad memories of other car chapters.
From cylinder 1-4
Cold compression numbers with no throttle applied.
135 140 140 145
Old Nov 2, 2019 | 02:09 PM
ItsmeWayne's Avatar
ItsmeWayne
Solid dampeners are not dampeners at all and not a good idea on a Mini! (crank pulley) It can cost you an engine.
Old Nov 2, 2019 | 03:11 PM
r53-06m6's Avatar
r53-06m6
Are you saying that this might have been the root cause of my problem here? I wouldn't expect any difficulties for quite some time if at all by going to a solid crank pulley. I searched here for days before reaching a cost/benefit decision in my case. I wouldn't think that installing a solid crank pulley would cause an immediate issue.
Old Nov 2, 2019 | 07:53 PM
ItsmeWayne's Avatar
ItsmeWayne
No, but what I am saying: The aftermarket solid crank pulley can cause vibrations, that can blow the oil pump and timing gear on the crank to break the internal front cover parts.
Old Nov 3, 2019 | 11:24 AM
A383Wing's Avatar
A383Wing
My thought on this is.......if a solid crank pulley is OK on a "S" engine...why didn't the factory use them?
The engineers weren't dumb....they knew what worked and what didn't
Bryan
Old Nov 3, 2019 | 03:57 PM
r53-06m6's Avatar
r53-06m6
Roger. The post has really begun to drift off topic though. I have read the numerous threads arguing back and forth, but the car starts and runs so this thread can die now.
Old Nov 3, 2019 | 04:21 PM
JAB 67's Avatar
JAB 67
I beg to differ. Someone may stumble upon this thread and think "maybe I too should install a solid crank pulley." What we are asking is, what search logic led you to the conclusion that notwithstanding what the BMW/MINI engineers had decided by installing a damped crank pulley, an aftermarket solid pulley would be better?
Old Nov 4, 2019 | 04:02 AM
r53-06m6's Avatar
r53-06m6
If someone wanted to do that, then they could hit the search button and run a query just like I did. The same applies to you. A cost/benefit analysis is relative to each person and as the old cliché goes, "it is my car".
Don't be a concern troll.
Old Nov 4, 2019 | 05:30 AM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
To the OP, would you mind telling us what the cause of the "no start" was and what you did to rectify same?
Old Nov 4, 2019 | 05:39 AM
r53-06m6's Avatar
r53-06m6
Unsure of the root cause. When checking compression, I pulled the plugs and noticed that they were fuel fouled. Definitely a symptom, but not the root cause. No codes. The car had been sitting for a while.
bavmotors
May 10, 2020 10:00 PM
R53.Lui
May 12, 2017 03:17 PM
screwed36coupe
Nov 20, 2013 08:28 PM
niquemarshall
11
Jan 14, 2012 09:43 AM
Rated_R
Aug 2, 2011 09:37 PM
