R52 Swaybar install on MCS Convertible
Old Dec 9, 2004 | 07:55 PM
BlackSpyder's Avatar
BlackSpyder
I just installed a 22mm swaybar and it's not that straight forward. The convertible has an additional rear subframe bolt (5 total) in the middle of the subframe, right above the exhaust pipe.
I had to remove the cross brace (center only, you can swing the arms out) then i proceeded to drop the exhaust with a jack underneath it and remove the heat shield enough to reach center bolt.
In all a little more work than expected but the results were worth it.
First ride was great but seem to soften a little after a few runs. Has this happen to anyone else with rear swaybar install?
squawSkiBum
Oct 2, 2015 09:21 AM
massmini03
Aug 12, 2015 11:19 AM
tag1260
Aug 5, 2015 04:27 AM
