brake pad sensor accuracy?
Old Dec 9, 2004 | 04:22 PM
ZAMIRZ's Avatar
ZAMIRZ
The light went off so I jacked the car up, took the wheels off and had a nice look around. Fronts have at least 40% and rears over 50% life left in them. So is the light supposed to go off this early or is there a sensor malfunction?
BTW, car is an '04 S with just over 16,000 miles on it. Almost all driving has been city with canyon runs about once a month or so.
Old Dec 9, 2004 | 04:53 PM
sfjames2's Avatar
sfjames2
zamirz, I recently helped a friend change brake pads for the same reason. What we noticed after taking the caliper off the car was that the inside pads (pad piston pushes on) were worn more than the outside pads by half.
So be sure to check the inside ones.
Old Dec 9, 2004 | 05:02 PM
MyPocketRocket's Avatar
MyPocketRocket
Which one is the brake pad sensor?...I mean which light is that you're refering to?
Old Dec 9, 2004 | 06:21 PM
ZAMIRZ's Avatar
ZAMIRZ
james, thanks for the heads up, I'll look at the inners more closely.
pocketrocket, the light is the yellow circular one in the speedo and shows a circle with 3 white dashes on each side.
Old Dec 10, 2004 | 12:44 PM
jwardell's Avatar
jwardell
The light should only go off if the sensor itself has physically been worn (and then it must be replaced). It slides into the pad, and can easily be slid out to check, or seen from the contact side of the pad.
HaveATank
Sep 4, 2015 08:04 AM
Aug 25, 2015 09:18 AM
HaveATank
Aug 24, 2015 10:26 AM
