R56 Do I have adaptive headlights?
Old Oct 13, 2019 | 09:36 AM
dale_z28's Avatar
dale_z28
2012 MCS. My manual shows a position on my turn signal stem which I don’t have -rotate to below the “off” position..yet when I replaced the Xenon bulb I see the mechanism for this system (the ball is actually broken on the right side headlamp, allows it to swing right to left freely)
could the factory have installed these headlamps without the controls, or might there have been an upgrade where the stem didn’t have this switch position?
Old Oct 13, 2019 | 05:38 PM
AZdsrt's Avatar
AZdsrt
Our 2012 with HID only go up and down, not left and right.
Old Oct 14, 2019 | 03:19 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The notch below the “Off” position is for “Automatic” headlights - for the headlights to switch on automatically in the dark. The HID headlights have auto-leveling, which is probably the mechanism you saw inside the headlights.
Old Oct 14, 2019 | 04:15 AM
cristo's Avatar
cristo
Alliance Member
There is an adjustment screw for horizontal
alignment (and another one for vertical
adjustment) on the outside of the headlight.
The lever for this inside the headlight is likely
broken, allowing it to flop back and forth.
I had this problem.
Old Oct 14, 2019 | 07:22 AM
dale_z28's Avatar
dale_z28
Thank you. I think that must be what happened to this one.
iranman
Oct 4, 2019 10:42 PM
smokeysevin
Electrical
Mar 16, 2014 01:02 AM
Mauricio328
Sep 10, 2011 02:37 PM
JudgeS
11
May 18, 2011 05:09 PM
april4jsd
Electrical
Feb 12, 2007 05:06 PM
