R56 Centre Armrest
Old Oct 4, 2019 | 07:04 PM
hxkenneth's Avatar
hxkenneth
Centre Armrest
Recently picked up an R56 after (regretfully) selling mine a few years back. It came with the gray center arm rest with black cushion like my old one did but I can't remember how it used to work.
The arm rest sits lower than horizontal, almost touching the handbrake and while I can lift it higher, there are no other locking points. Is this the intended behaviour or is it broken?
Old Oct 5, 2019 | 04:22 AM
texasmontego's Avatar
texasmontego
It shouldn’t rest on the Ebrake handle. In the down position, the center console should be level/horizontal.
https://www.realoem.com/bmw/enUS/sho...diagId=51_6289
Old Oct 5, 2019 | 06:24 AM
hxkenneth's Avatar
hxkenneth
Thanks. I will look for a replacement then. This part seems unnecessarily expensive though!
Old Oct 9, 2019 | 10:47 AM
texasmontego
Take it apart and find out why it’s leaning forward before you go looking for a replacement console. Could be a simple fix.
Old Oct 10, 2019 | 02:19 PM
Picture of how it looks?
Old Oct 13, 2019 | 03:20 AM
hxkenneth's Avatar
hxkenneth
Sorry I dont have a picture because its fixed now. I added an aluminium at the hinge stop so the arm rest stops higher up. It is MUCH more comfortable in this position and I also took the chance to lubricate the hinges too. This required only the removal of 2 screws on the sides of the cupholder, another screw in the middle of the cupholder itself. Quick fix and made it so much better. I don't know if it was always intended to sit so low but the hinge stop is made of a hard rubber type of material so I guess it could have worn down over the years.
I'm looking for a stiffer spring or some other way to modify it to stop the cushion from sliding back so easily now that I can comfortably use the armrest.
vetsvette
Oct 17, 2015 06:07 AM
peatun
Mar 28, 2013 08:29 PM
minikart4me
May 3, 2008 08:27 PM
OrneryDSMini
Mar 25, 2008 01:11 PM
harley0711
Aug 22, 2007 08:25 PM
