FS:: N14 Turbosmart Kompact EM Recirc Valve
Price: $150
Part fits (you may select multiples): R55, R56, R57
Location (Region): SouthEast
Hey everyone,
I'm selling a Turbosmart EM Series Recirc Valve for all modified/tuned N14 engines only. This is Turbosmart's newest electronically controlled solenoid valve. There is nothing wrong with the valve mechanically, and it was only used for about 400 miles. There are some scuff marks in the black coating on the exterior due to the close fit with the turbo coolant line, I've included photos of this to give you an idea. I'm selling it as I have the DoS intake, which means even recirc valves are loud, and I just prefer the sound of my old one.
PRICE: $150 + shipping, payment via Paypal
SOLD
NOTE: This is only recommended for modified/tuned N14 applications, due to the stiffness of the spring. It is not recommended for stock applications. The valve also has a removable shim (shown in the first photograph on the right) which alters spring pressure. I usually don't see more than 18-20psi and therefore didn't need the included shim. All you Stage 2, 3 and above people would probably want to replace the shim. To place the shim back in, you just unscrew the cap of the valve and slide it in under the spring, then reattach the cap. If you know you'll want it back in I'm happy to reinstall it before sending the valve out.
I am including everything that came with the valve originally: the valve, Turbosmart decal, attachment screws and shown below is the removable shim.
Part number for the valve is TS-022301293. Manufacturer details can be found here.
