R50/53 Heater core clamps
Old Sep 25, 2019 | 02:15 AM
Island_Moose's Avatar
Island_Moose
Heater core clamps
Bought a new set of clamps and seals after de scaling the heater core. For the life of me I cannot hold the pieces together and fasten the clamp around the joint at the same time. Tricks?
Old Sep 26, 2019 | 02:18 AM
Island_Moose
Got them. I have a couple tricks if anyone’s interested.
Old Sep 27, 2019 | 02:00 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
I am just curious. Did you use de-scaler to descale like with citric on the heater core? Are these clamps and seal for the heater and fan blower housing?
Old Sep 30, 2019 | 12:57 PM
Island_Moose
I used 4 different steps to clean the heater core. I started with a pressure washer in both directions, catching it all in a large tub to evaluate the scale I was removing. I then soaked the unit in industrial strength degreaser. Then I soaked it in boiling water and flushed it again with the pressure washer. Finally I soaked it overnight in CLR and rinsed it thrououghly with soapy water.
The clamps connect the aluminium tubes to the heater core under the dash.
I could not squeeze the ends together and get the clamps on properly at the same time. I took two zip ties and made them into 1" loops. Using duct tape I secured these loops about 6" up the aluminum pipes away from the joint. I have a number of quick clamps (the ones with the trigger grip) which I hooked through the loops and pulled against the manifold section of the heater core. This pulled the 2 section together tightly and allowed me to take my time with a small inspection mirror to ensure the clamps went on properly. I find few things to be impossible but holding the tubes in place by hand and getting the clamps around both flanges was impossible.
Redhotz
R55 :: Clubman Talk (2008+)
Sep 22, 2015 09:41 PM
ghas
Oct 27, 2014 02:50 PM
GuyPavelo
Mar 10, 2013 12:43 PM
minimikeG
Dec 27, 2011 11:24 PM
