iOS 13 update issues
Old Sep 24, 2019 | 12:58 PM
Jimmys's Avatar
Jimmys
Is anyone having an issue where the CarPlay keeps cutting out after iOS13? I also got the iPhone 11 pro so I can’t tell if it’s the software update or the new phone. 2019 F56 with HK system.
Old Sep 24, 2019 | 06:00 PM
sb2002's Avatar
sb2002
Since iOS 13, my CarPlay keeps interrupting any other media, so if I’m trying to listen to the radio, CarPlay interrupts and tries to play what I was last listening too on my phone, or just interrupts and plays nothing.
I’m using an iPhone X and having problems, so I don’t know that I’d blame the new phone.
Old Sep 24, 2019 | 06:35 PM
vetsvette's Avatar
vetsvette
Moderator
They came out with IOS 13.1 today because of multiple glitches with 13.
Old Sep 24, 2019 | 06:45 PM
Stu's Avatar
Stu
I have an 11Pro and have had no such issues
Old Sep 24, 2019 | 07:14 PM
sb2002's Avatar
sb2002
I’ve updated to iOS 13.1 and I’m still having the same problem. Everything worked fine before the update to iOS 13.
I have a second phone for work - I’ll update it to iOS 13.1 soon and see if CarPlay works any better with it.
Old Sep 25, 2019 | 05:51 AM
Jimmys's Avatar
Jimmys
I read in other forums that resetting the blue tooth on the car might help. The also said to unpair, delete any phones, delete the CarPlay from your phone, and start from fresh.
Old Sep 25, 2019 | 12:25 PM
6FT6's Avatar
6FT6
This always works. I have 13.1 on an X and all is well.
Old Sep 25, 2019 | 12:31 PM
Jimmys's Avatar
Jimmys
Well I did all that and I'm still having issues.....
Old Sep 25, 2019 | 12:35 PM
6FT6's Avatar
6FT6
Damn...sorry bud!
Old Sep 25, 2019 | 12:46 PM
Jimmys's Avatar
Jimmys
Yea...... BTW if I turnoff CarPlay and just use Bluetooth, it plays fine.
Old Sep 25, 2019 | 02:17 PM
sb2002's Avatar
sb2002
Same here. I’m going to be traveling for a few days, but when I get home, I’m going to try Reset All Settings on my phone and see if that helps any.
Old Sep 26, 2019 | 01:48 PM
Jimmys's Avatar
Jimmys
Tried pairing my wife's phone, same as mine. And I have the same exact issue.
Old Sep 29, 2019 | 04:36 PM
sb2002's Avatar
sb2002
Earlier today, I reset all settings on my phone (General/Settings/Reset/Reset All Settings), and then deleted my iPhone as a mobile device from the car. After reconnecting my phone to CarPlay, so far, everything is working properly. I'll give this another day or two and post an update.
Old Sep 30, 2019 | 06:53 PM
sb2002's Avatar
sb2002
Just to follow up on my prior post, after resetting all settings on my phone (not erasing all content - just resetting all settings), my CarPlay is now working fine.
Old Oct 3, 2019 | 11:04 AM
Jimmys's Avatar
Jimmys
Well now I have confirmation that a second MINI with wireless carplay is having the same issue as my car with the iPhone 11Pro.
Old Oct 4, 2019 | 01:19 PM
Krut's Avatar
Krut
same issue 13.1 os with 2020 JCW Clubman
Paired it up when I purchased my car on Wednesday - last night going around a corner CarPlay gave up the ghost but was able to play just fine on Bluetooth. I'll reset settings tonight and update to the latest OS to see if that helps.
Old Oct 5, 2019 | 12:36 PM
sb2002's Avatar
sb2002
Any news?
Old Oct 5, 2019 | 02:13 PM
6FT6's Avatar
6FT6
Really odd that you folks are having issues.
Old Oct 7, 2019 | 08:53 AM
Jimmys's Avatar
Jimmys
Thanks for sharing! I have posted the issue on other Apple related forums to hopefully get attention of apple engineers.
Old Oct 7, 2019 | 08:54 AM
Jimmys's Avatar
Jimmys
I believe the issue is tied to the 11Pro, the iPhone X does not seem to be affected
Old Oct 7, 2019 | 11:29 AM
BendersMINI's Avatar
BendersMINI
Having the same issue with my 2018 F54 and iPhone XS. Stopped for gas on Friday and when I turned the car back on CarPlay no longer worked. Have unpaired and forgotten the device, resynced, but still no luck with CarPlay. As with everyone else, connecting only with Bluetooth works fine. Running iOS 13.1.1, but will try updating to 13.1.2 today to see if that helps.
Are you saying that you're going into iOS settings - General - Reset - Reset All Settings and then CarPlay works again? Sounds like a pain to go back and then adjust every app again to configure the phone settings as I prefer.
Old Oct 7, 2019 | 11:49 AM
sb2002's Avatar
sb2002
Yes - I went to iOS settings: General/Reset/Reset All Settings. I then told my car to forget my phone, and then re-paired the phone to the car, and things have worked well since.
I agree that it is a pain, but my CarPlay has worked fine since.
If you try it, let me know if it works. So far, I don't know if anyone else has tried.
Old Oct 7, 2019 | 12:34 PM
Jimmys's Avatar
Jimmys
Yes I have, issue continues. But I have an iPhone 11Pro
Old Oct 7, 2019 | 01:13 PM
sb2002's Avatar
sb2002
Jimmys - thanks for the clarification. I'm sorry to hear resetting the settings had no benefit for you.
Old Oct 7, 2019 | 03:04 PM
Warren2185's Avatar
Warren2185
My head-unit doesn't have car play (It's non- NAV - 6.5 "), but with the iOS update I can no longer select my playlist songs with the iDrive scroll wheel and pushing down. I used that constantly before..There are reports all over that this happened. I hope it gets sorted out soon. It used to work over Bluetooth and plugged in.
