R56 A/C click noise under the dash
Old Sep 23, 2019 | 08:27 AM
miniuy's Avatar
miniuy
This MINI Cooper 2010 with manual air conditioning was 3 months in the garage.
The A/C works as expected in any of the 5 positions (feet, windshield, panel) in hot, neutral or cold function.
The issue occurs when changing the A/C button from one position to another one (consecutive or non-consecutive, in any direction).
There is something behind the speedo or the dash doing a clicking noise (3 or 4 clicks, 2 per second)
Could it be that after so many months without using the car something needs to be lubricated?
Do I have to disassemble the entire dash to get to the system?
I really don't know what to expect or what I'm going to find ...
Old Sep 23, 2019 | 11:44 AM
MADNESSray's Avatar
MADNESSray
I think you might have a faulty blend door. It is the actuator that moves when choosing hot to cold and even the positioning, I think. I'd assume that it is located near the blower motor which is accessed through a panel on the right side in the driverside foot well.
Hope that helps.
Old Sep 23, 2019 | 01:09 PM
miniuy's Avatar
miniuy
Hope that helps.
I have read something related the actuator failing, but since I hear the noise coming from the speedo zone and not from the cabin filter area I discarded that option.
Now I'm going to replace this part and I will let you know.
Thank you for your reply
Old Aug 16, 2021 | 10:08 AM
hndle's Avatar
hndle
I had the same thing happen suddenly last weekend. I went shopping at one store, then after I went to leave, the noise started. There's a youtube where the guy shows how to remove the filter. I did, then reached up into the cavity and felt for the blower cage, and there was a straw wrapper.
johnshumpert
Mar 18, 2011 05:15 AM
russr
Apr 10, 2008 11:00 AM
Derosi
Dec 8, 2007 06:45 AM
twin scroll
Oct 15, 2007 01:14 PM
Oban2002
DC Metro MINIs (Archive)
Mar 4, 2005 07:38 AM
