F55/F56 What do you use to clean wheel arch trim?
Old Sep 14, 2019 | 05:57 AM
spyked's Avatar
spyked
Hi everyone. What product do you use to clean the black plastic wheel/fender trim? Over the last almost 3 years mine have started looking dirty and have white streaks. It's not like Jeep Wrangler fender flare gray fading yet, but you can see soap and wax residue. How can I clean the trim thoroughly without fading them from black to gray?
Thanks!
Old Sep 14, 2019 | 07:52 AM
USA-RET's Avatar
USA-RET
Thanks!
I've used spray 409 on mine. If I want to restore the darker black color I use "Back to Black" on the flare. If you hand wax, be doubly careful to keep any wax off them, That stuff never seems to come off regardless of what I've used.
Old Sep 15, 2019 | 04:00 PM
Lucila's Avatar
Lucila
I’ve been using Black Wow for the past three years. It’s been better and longer lasting than other products I’ve used. I recently bought PreWow to clean and prep the plastic. It has helped tremendously in keeping my flares black and clean for much longer than just the Black Wow alone.
Old Sep 15, 2019 | 05:54 PM
ASKtheteach's Avatar
ASKtheteach
I’ve actually had a lot of luck with Armor All Outlast. It’s a cream you apply with a microfiber or Ian applicator and then buff off any excess. Goes on easily and lasts a while (usually several months).
Old Sep 15, 2019 | 05:58 PM
Fly'n Brick's Avatar
Fly'n Brick
+1
Black Wow is the stuff. Go visit the old "Detailing 101" section, everything you need to know resides therein. Richard Lin shared a lot of wisdom,
https://www.blackwow.com/
https://www.showcardetailing.com/
Old Sep 16, 2019 | 06:28 AM
spyked's Avatar
spyked
Thanks everyone! I hope to take a few hours to attack the trim this coming week or weekend. I had to use some actual black dye to fix the trim under the windshield that had actually gone gray/nearly white. I glad the fender trim isn't that bad yet and will hopefully prevent more damage by cleaning and treating them.
Old Sep 19, 2019 | 07:15 PM
pongobaz's Avatar
pongobaz
My wiper cowl was fading too and I had it replaced by the dealer under warranty just last week.
Old Sep 21, 2019 | 11:50 PM
Lucila's Avatar
Lucila
I asked my service advisor about it and she said Mini wouldn’t do it. :(
Old Sep 23, 2019 | 05:14 AM
10BRG's Avatar
10BRG
Try 303 Protectant. Brings the black back and has UV inhibitors. Great on all exterior black rubber and plastic and interior vinyl. Goes on easily then buff dry.
Old Oct 1, 2019 | 02:30 PM
Chemical guys VRP.
Old Oct 1, 2019 | 03:30 PM
Capt_bj's Avatar
Capt_bj
https://www.zymol.com/vinylconditioner.aspx
Old Oct 20, 2023 | 07:54 PM
Tombstone's Avatar
Tombstone
Chemical guys VRP.
VRP is great for tires and gives them the right sheen but, sucks on interior plastics , doesn’t last and actually leaves streaks on window control panels. Plus , their customer service is terrible ….
Old Oct 23, 2023 | 05:31 AM
F5666's Avatar
F5666
Mother's Back-to-Black. Hands down.
Old Oct 23, 2023 | 09:16 AM
RichsMINI's Avatar
RichsMINI
If you're looking for a multi-year solution I would recommend looking into AMMO NYC Frame Pro Trim Coat
- Easy to apply! Going on two years since the first application and the trim looks better than new
https://ammonyc.com/products/ammo-frame-pro-trim-coat
Before applying you need to degrease the wheel arch trim with dish soap or their Brute Wheel soap
https://ammonyc.com/products/ammo-brute-wheel-soap
Hope this helps and motor on -Rich
Old Oct 24, 2023 | 07:34 AM
russmini's Avatar
russmini
I tried Sonax Tire Gloss on the trim as I use it on my tires. Works really well.
davidg5700
Detailing 101
11
Nov 4, 2013 09:03 AM
mbu
Detailing 101
28
Dec 5, 2010 09:13 PM
Mekidon
Apr 11, 2010 11:03 PM
BradB
Detailing 101
15
Sep 29, 2004 07:31 PM
Dan_C
Sep 16, 2003 01:42 PM
