JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
What JCW parts are avail for the 2016 R60?
Old Sep 4, 2019 | 09:53 PM
OSilvera's Avatar
OSilvera
Hi folks.
I have a beautiful 2016 Countryman S that I got new and now crossed the 50K miles mark and I'm starting the mods and upgrades.
If it's not too much trouble, what JCW parts were factory available options for my 2016 R60?
I have the JCW split front lower lip on the bumper and added the JCW sport comp gauges a while back.
Added the Turbo delete from WMW, the NM Carbon cold air intake, a Megan top strut bar, some 19" Paceman rims I had powdercoated gloss black.
most likely going to add an Intercooler, down pipe and stage 2 ECU tune from NM.
But I'd like to start adding some JCW items...
I just scored the front and rear sway bar from the jcw sport suspension.
What else is there underneath the car?
Any thoughts?... Any parts?....
Thank you..
Ozzie
Old Sep 5, 2019 | 07:11 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Don't bother doing the JCW sway bars they won't make enough difference for the cost of install as they aren't stiff enough.
If you want a real improvement and reduced body roll go with our WMW rear bar
https://www.waymotorworks.com/wmw-co...-sway-bar.html
Then later if you feel you want to upgrade the front which most don't until they are doing other work that already has the front subframe out you can do our H&R bar
https://www.waymotorworks.com/h-r-fr...ybar-mini.html
Otherwise for suspension I'd look for going to the KWs as they really improve the handling and ride good.
https://www.waymotorworks.com/kw-var...ountryman.html
jbluesky
Aug 31, 2019 06:41 AM
tmehanna
Oct 13, 2015 02:56 PM
NeoBear
15
Aug 1, 2015 05:38 AM
Chibi-Mini
Jul 30, 2013 11:31 AM
liveSTRONG
May 5, 2012 03:00 PM
