R50/53 Supercharger service advice
Old Sep 3, 2019 | 12:32 PM
speedman's Avatar
speedman
I have the changed the supercharger oil and gasket. Before I start putting the car back together is there any jobs I should do?
Here is what I have done while the supercharger is off and the car is in front end service mode
1) replaced the water pump and O rings
2) replaced the upper and lower radiator hoses
3) replaced the MAP sensor hose
4) replaced the green gasket
Old Sep 3, 2019 | 01:29 PM
JAB 67's Avatar
JAB 67
crank position sensor o-ring
Old Sep 3, 2019 | 01:46 PM
cooper48's Avatar
cooper48
+1 on JAB 67's post. That sensor is a well-known oil leak and it's super easy to get to (front of the block) with the supercharger removed.
Old Sep 3, 2019 | 05:00 PM
mslatter's Avatar
mslatter
I’d replace the serpentine belt, belt tensioner and idler pulley, if that’s never been done. While you’ve got the cooling system empty, I might recommend replacing the coolant overflow tank with a metal one since the plastic ones fail regularly. I did the dipstick o-ring at the time I did my s/c. And be sure to check all the vacuum tubes. I’d do a smoke test while I still had the s/c off, just because you’ll have somewhat better access to some of the tubes. And if you had any oil on the block, clean it off so you can more easily spot fresh leaks.
Old Sep 3, 2019 | 05:13 PM
speedman's Avatar
speedman
Thanks for great advice. I will get parts on order
Old Sep 3, 2019 | 06:33 PM
tej98's Avatar
tej98
While I had my car in front end service mode I went ahead and also cleaned the throttle body and bypass valve. These can be done with the car back together, but it is a bit easier with the front end off. I also changed the throttle body gasket and the circular seal between the bypass valve and the driver's side intercooler horn (mine was flat and causing a vacuum leak).
Solamar
Jun 12, 2018 09:20 AM
madmike007
Feb 24, 2017 09:55 AM
LTEAPX
Dec 13, 2016 09:03 AM
Deluded
Dec 7, 2014 04:04 AM
mgriff41
Middle Georgia MINIs
Dec 31, 2011 02:34 PM
