Steering wheel vibration
Old Dec 7, 2004 | 01:24 PM
UnMini's Avatar
UnMini
My MCS has recently developed a problems since I changed my runflats for normal tires. When I am driving over 90 or 100 Mph and I hit the brakes the steering wheel starts to vibrated a lot. The vibration reduces and almost disapears when the car slowes down to about 50 Mph. Do I need to re balance the tires, is something wrong with the brakes or is something else wrong?
Old Dec 7, 2004 | 01:33 PM
Wenzor's Avatar
Wenzor
are you running aftermarket wheels? I had the same problem but with aftermarket wheels that were not hub centric. got hub centric rings put in and the car is super smooth again.
Old Dec 7, 2004 | 01:49 PM
MGCMAN's Avatar
MGCMAN
Exactly,
Sounds like a rebalance is needed if you put non-runflats on your stock rims. But if you are running non-stock rims, make sure that you have hub-centric rings in place, otherwise you will drive yourself crazy trying to stop the vibrations.
Also re-torque all your wheel studs to 90 Lb., sometimes after a change the studs will loosen up and need to be re-torqued.
Old Dec 7, 2004 | 11:14 PM
UnMini's Avatar
UnMini
Thanks for your replies. I am running stock wheels
Manny_cooper
Sep 10, 2015 11:09 AM
Colt45Magnus
Sep 7, 2015 10:47 PM
trw92a
Aug 26, 2015 01:47 PM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
