R60 high beam signal wire
Old Aug 26, 2019 | 02:56 PM
Mooogden's Avatar
Mooogden
Does anyone know what color the signal wire is for the high beams. I am in the process of installing some driving lights and need to connect to this wire to have them come on with the high beams. I have all of the other wiring sorted but this is the one connection left before i can test them out.
Old Aug 27, 2019 | 08:51 AM
rkw's Avatar
rkw
If you have halogen headlights, the high beams should be white/green (pin 6) on the left headlight, and white/blue (pin 6) on the right headlight.
https://www.newtis.info/tisv2/a/en/f...hts/1VnXg0CH9q
If you have LED headlights, everything appears to be integrated inside the electronics module with no external lines you can pick up.
https://www.newtis.info/tisv2/a/en/f...ght/1VnZ3pw7Ey
Old Aug 27, 2019 | 10:10 AM
MVPeters's Avatar
MVPeters
rkw
With respect, I don't think that's the best place to make the connection.
Mooogden has H7 halogen bulbs - there are only 2 wires, 12V & ground. I can check the colors on my R53 but they may be different.
I'd make the relay trigger connection there, although it might depend on where the relay is - mine is right behind the headlight.
Old Aug 27, 2019 | 11:47 AM
rkw's Avatar
rkw
I linked the wiring diagram and pointed out the wire colors. Not sure what your objection is.
Old Aug 29, 2019 | 04:00 AM
pocketmaster's Avatar
pocketmaster
My + coil for the relay is linked to my + high beam wire (much less draw than using the high beam + for the battery feeding the driving lights).
Old Sep 6, 2019 | 10:38 AM
MReiland's Avatar
MReiland
https://www.northamericanmotoring.co...tructions.html
Evasive
Electrical
14
Mar 3, 2012 08:54 PM
Kazy
Electrical
May 17, 2009 06:22 PM
Sin MINI
Electrical
Jun 28, 2008 10:02 AM
Sin MINI
Jun 23, 2008 08:11 AM
JPit
Electrical
Mar 2, 2008 09:30 PM
