Engine Knock, Need Ideas
Old Aug 24, 2019 | 04:21 AM
texasmontego's Avatar
texasmontego
Working on a friends car. 2010 Justa. The knock started the other day. I first thought it was the timing chain, but after removing the valve cover and inspecting, it doesn’t appear to be the problem. Inspected the spark plugs and no unusual misfire. No CEL’s either.
I made a short video with the sound.
https://drive.google.com/open?id=1VL...YX54_1NDwNRHf8
Any ideas?
Old Aug 24, 2019 | 04:25 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Did it run low on oil at some point? Knocking is never good... Timing chain would be a rattle. Misfire would make the engine run rough.
Old Aug 24, 2019 | 05:11 AM
texasmontego
Let’s assume, yes, it got low on oil. It was a quart low when they brought it over for me to inspect.
Old Aug 25, 2019 | 08:09 AM
texasmontego
Corrected the permissions. You should be able to see the video now
Old Sep 3, 2019 | 06:23 AM
MiniToBe's Avatar
MiniToBe
check the serpentine belt.
Old Sep 3, 2019 | 07:49 AM
cooper48's Avatar
cooper48
That has all the sounds of a bad rod bearing. If it suffered oil starvation for any length of time, that would be an obvious condition.
Old Sep 3, 2019 | 08:01 AM
MiniToBe's Avatar
MiniToBe
If you noticed, the sound does NOT get louder as he revs the engine. It stays the same pitch but becomes faster. for that reason I bet it is not a bad rod bearing but a $10 belt...I had a NAM member bring me his car for the same "shop diagnosis" only to find a chipped belt...poor guy was asked to replace his engine by two shops!!
Old Sep 4, 2019 | 04:42 AM
texasmontego
That is correct, the sounds does NOT get louder with RPM’s. For the cost, the belt is an easy and cheap part to replace and see what happens. My neighbors 17 yr old daughter drives the car and they aren’t auto people, so they always take their cars to the dealer or shop. If I had to guess, they never check the oil, so I can’t say for sure if it was ever low and overheated.
I’ll post the results after I replace it.
Old Sep 4, 2019 | 05:02 AM
MiniToBe's Avatar
MiniToBe
While you at it, check the pullies. Sometime they chip away from thr inner side (crankshaft and water pump pulley).
Old Sep 21, 2019 | 08:35 PM
texasmontego
Found the solution. MiniToBe called it, Serpentine Belt. Some of the ribs had broke off and when it passed through the friction wheel, it “bumped” causing the sound.
Replaced the belt, silent as a mouse.
Old Sep 22, 2019 | 06:49 AM
Cenla Mini's Avatar
Cenla Mini
Wow...now that's a belt that needed to be replaced!
Old Sep 23, 2019 | 05:47 AM
MiniToBe's Avatar
MiniToBe
Blacked Out 2010
R57 :: Cabrio Talk (2009+)
Oct 29, 2015 06:00 AM
Yakatak
Aug 29, 2014 09:14 AM
fjork_duf
Mar 13, 2013 06:47 PM
yyj3869
Mar 29, 2012 07:16 PM
phantasms
May 18, 2010 08:59 AM
