Hard Brake Line Broke - Fix or Replace
Old Aug 21, 2019 | 02:30 PM
Mcschobert's Avatar
Mcschobert
2007 Mini Cooper Base. What started as a routine brake/route job has turned into a nightmarish project. While I was unscrewing the brake hose from the hard brake line on the rear passenger side, the fitting on the hard brake line twisted off and I'm not sure how to fix it. Should I replace the entire line or can I cheat and patch in a replacement line? When I was trying to trace the hardline, it looks like it's going to be a huge PITA to replace, but that's just from eyeballing it will on jack stands.
Also, the bolt that holds the rotor to the hub is seized, so that's another fun project. After some PB Blaster and a hit with the impact gun, it's still not budging. Thank you, Wisconsin winters!
TIA!
Old Aug 22, 2019 | 06:22 AM
michaelo's Avatar
michaelo
Brakes are important and if you are not sure how to fix it, then take it to somebody who does. Cheat and patch a break line...? Ohhhh boy.
bdubya
May 25, 2019 08:39 AM
Greenmachine13
Tires, Wheels, & Brakes
Jun 7, 2017 06:29 PM
graveshaker
14
Dec 17, 2015 08:34 AM
micromini234
Jun 6, 2013 02:39 PM
elliott
May 8, 2011 08:32 PM
