P0088 and P1216 code causes?
Hi all. We have a 2009 cooper S R56 with less than 30K miles on it. After not running it for a while, it was slow to start and ran rough at idle. On restart the yellow engine light comes on, but it seems to run OK above idle. Then if you let the revs go down to idle, it goes into limp home mode.
Auto zone read the codes as P0088 (high fuel rail pressure) and P1216 (fuel pump emergency operation). I replaced the fuel rail pressure sensor, and put in new injectors and high pressure fuel line while I was there.
However, the symptoms and codes persist. Anybody know what’s causing the problem?
Tah1
Hey got same issue, but changed O2 sensor, all 4 ignition coils, maf sensor, HPFP, map sensor, and fuel filter. Got P0088, P1216, and a P2097. Which is saying pressure to high at fuel rail and not enough air to fuel mixture. Did you ever figure out your issue? Please let me know thanks
RCRacer
R60/R61 Stock Problems/Issues
Feb 7, 2019 11:07 AM
