P0088 and P1216 code causes?
Old Aug 13, 2019 | 11:34 AM
TAH1's Avatar
TAH1
Hi all. We have a 2009 cooper S R56 with less than 30K miles on it. After not running it for a while, it was slow to start and ran rough at idle. On restart the yellow engine light comes on, but it seems to run OK above idle. Then if you let the revs go down to idle, it goes into limp home mode.
Autozone read the codes as P0088 (high fuel rail pressure) and P1216 (fuel pump emergency operation). I replaced the fuel rail pressure sensor, and put in new injectors and high pressure fuel line while I was there.
However, the symptoms and codes persist. Anybody know what’s causing the problem?
MiniCooper_S
Feb 17, 2023 07:47 AM
TAH1
Oct 22, 2019 08:06 PM
RCRacer
R60/R61 Stock Problems/Issues
Feb 7, 2019 11:07 AM
HowardH
12
Jan 21, 2019 11:22 AM
