New used Mini
Old Aug 13, 2019 | 09:50 AM
Rjgogo's Avatar
Rjgogo
New used Mini
Just picked up a 2012 Mini hatch non s. It as 82 K on the clock and a manual transmission. Not knowing the last maintenance that was done for sure I plan to change both the Oil and trans fluid, I did not a search but since I am new to the Mini don't know the differences between the various years yet so a couple of questions.
1. What fluid should I use in the manual. Redline MTL Okay, Pennzoil Sycromesh? Something else? Looks like 1.8 quarts I know there is BMW spec stuff in the manual but that is not available locally for me.
2. Oil 5-30 synthenic little less than 5 quarts from what I read.
3. Plan to rotate the tires
4 Anything else come to mind to check?
I did do a check on the clutch and it seems good. kills the engine immeadiatly from a dead stop in in 4th with the e brake on.
Thanks in advance.
Jckol
Jun 16, 2016 09:53 AM
AkFarina
Feb 7, 2009 09:07 PM
NashvilleMiniStan
Sep 16, 2008 08:51 AM
Squadron
Mar 25, 2008 07:19 AM
kapps
Aug 1, 2005 06:55 PM
