Best way to clean exhaust tips?
Old Aug 10, 2019 | 12:28 PM
Squirrelly's Avatar
Squirrelly
I've long neglected cleaning my exhaust tips and they're crusty nasty now. What's the best method to clean them? I tried a Brillo pad fortified by Ajax powder but it made little change in the appearance. Oven cleaner? Help!
Old Aug 10, 2019 | 12:43 PM
Fly'n Brick's Avatar
Fly'n Brick
Strange, I use Barkeepers Friend with a spritz of my own chemistry. Some vinegar, isopropyl alcohol and a squirt of Dawn detergent and water. Works great on kitchen cabinets too. They come out sparkling, exactly what I was going to suggest.
Old Aug 10, 2019 | 01:24 PM
tc1728's Avatar
tc1728
Some fine steel wool, some simple green, some elbow grease followed by some aluminum polish is what works for me
Old Aug 10, 2019 | 01:37 PM
Capt_bj's Avatar
Capt_bj
best way to clean them
as you've already learned
is FREQUENTLY!!
if you stay on top the grime just wipes off in the course of normal washing.
over time you may get some color change from metal 'cooking' but unless you polish (aka remove some surface material) you aren't going to change that
Brillo pad ... steel wool ..... heck even my 79 ain't seen that
Old Aug 10, 2019 | 02:00 PM
RudeJoe's Avatar
RudeJoe
Lacquer thinner works really well to cut the grime/soot. I stumbled across this while cleaning off the black trim with it on my '06 R52. Just wipes off the build up with very little effort
Old Aug 10, 2019 | 02:48 PM
Brainygadgetgirl's Avatar
Brainygadgetgirl
We use white vinegar diluted with water (about 2/3 vinegar, 1/3 water). Spray it on, and then take a drill brush to the tips. This method took a bit of patience but all the caked on black crud came off... and a natural/cheap/eco friendly cleaner! Good luck!
Old Aug 10, 2019 | 08:30 PM
dube53's Avatar
dube53
SS Exhaust Tips..........
The secret is to take care of them every time you wash your car but it may be mostly impossible during winter. I don't let any heavy build up on them.
I use a chrome polish by Mothers that remove stain and rust. I also finish the job by using clay bar for any left residues. Mines are still shiny as new chrome.
Old Aug 11, 2019 | 03:40 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
This stuff actually works REALLY well for stainless exhaust tips:
https://www.homedepot.com/p/Cerama-B...10DS/202049920
Old Aug 12, 2019 | 01:19 PM
Squirrelly's Avatar
Squirrelly
Thanks for all the responses! Now I have multiple regimens to try.
Old Aug 12, 2019 | 08:02 PM
Aquavette's Avatar
Aquavette
Eagle One Nevr-Dull.
Old Aug 14, 2019 | 07:39 AM
Jim Dantin's Avatar
Jim Dantin
The common theory here seems to be, use a mild abrasive or solvent, combine with elbow grease, follow with polish, repeat frequently! :-)
Old Aug 14, 2019 | 07:18 PM
dmath's Avatar
dmath
Sounds like a formula to cure many ills.
Old Sep 17, 2019 | 12:54 PM
21JCW's Avatar
21JCW
I am a little late to the party here ....but wanted to share any extra tips ...
000 or 0000 steel wool works great and will not scratch the chrome assuming the chrome/stainless tips are of good quality.
Another good option is wheel cleaner ...
Both of which have worked well for me.
Old Mar 28, 2020 | 11:01 AM
joeybananaz18's Avatar
joeybananaz18
i used griots garage heavy duty wheel cleaner. let it sit on the metal for a couple of minutes and then scrub off with steel wool.
Old Aug 4, 2021 | 06:59 AM
TMolloy's Avatar
TMolloy
Barkeepers Friend takes the soot right off!
Old Aug 4, 2021 | 08:23 AM
veggivet's Avatar
veggivet
Griot's wheel cleaner, or any chrome cleaner, or the homemade vinegar recipes will do the trick. Once you've got the nasties off, a light wiping after each wash will keep 'em looking bright and shiny. Once they're all cleaned up, they will sound louder too! 😉
Old Aug 28, 2021 | 12:59 AM
MDMUS's Avatar
MDMUS
I think I discovered this either here or another forum: cooktop cleaner with their pad. Agree with others that it should be done around each wash, after a few months (or years) it becomes harder to remove and I fear scratching the chrome: Cerama Bryte Cooktop Cleaning Kit, available at the big box stores and online.
You can do a search on "Cerama Bryte exhaust" and find lots of posts on car forums about this.
Amazon Amazon
Squirrelly
Detailing 101
20
Mar 27, 2020 04:30 AM
isthar
Detailing 101
18
Jun 20, 2010 08:53 AM
Tiny1
Detailing 101
14
Mar 29, 2008 05:30 AM
crazyaboutmini
May 26, 2007 02:10 PM
karvinbass
Detailing 101
May 10, 2005 07:45 PM
