Navigation & Audio R53 with HK Weak Audio RH Side
Anyone encountered a weak audio from the RH speakers with their R53? I have replaced the door speakers, HK AMP, and still has weak audio. Next is the back speaker and head unit, Otherwise, it would have to be a audio wire somewhere that is corroded.
Thanks.
Thanks.
I had an issue in my R52. HK system but with an aftermarket head. The right speakers would cut out completely, but would often come back on again if I power cycled the radio. Pulled the head, pulled the door card, wiggled all the wire bundles with the radio running and never heard the speaker cut out. After reassembling, the problem has not recurred in 6 months, and it used to happen nearly daily.
Jerseygirl
37
Aug 25, 2003 04:16 PM
