R50 04 mini cooper s stereo wiring adding bluetooth help needed
Old Aug 3, 2019 | 04:48 AM
Compman2002's Avatar
Compman2002
I have purchased a aftermarket bluetooth adapter that says it is for the r50 mini cooper. The adapter is not being recognized by the stereo, the factory system I have has the HK package and the serius xm setup was wondering if the xm part is causing the bluetooth connection to not be recognized by the head unit?
Any help or info on this would be appreciated
Old Aug 4, 2019 | 05:27 PM
Compman2002
Fixed! I know have bluetooth although the quality is not great
Old Aug 4, 2019 | 06:10 PM
mslatter's Avatar
mslatter
Glad you were able to get it working. I ended up replacing the head unit with one that does Siri’s/XM and Bluetooth. I got it from Crutchfield and bought the Axxess adaptor with it. It’s an ugly pile of boxes and a little tricky to fit it all in, but it’s compatible with the H/K amp, and works with the steering wheel controls.
Old Aug 5, 2019 | 12:40 AM
Compman2002
Yeah I went with the
Bluetooth Adapter Bluetooth Adapter
from Amazon Automobil Pro Audio was a big help they even sent me a second box to test if the original box was faulty or not turns out it wasn't I am not too happy with the adapter though in that its a bit buggy, Pretty sure I can work through it though mainly having problems with alt and battery supply not being enough to handle the load I am giving them. So I am looking for a solution for a secondary battery placement the trunk is out of the question as it is housing my sub box and amp. Also looking for an upgrade to the alt any suggestion in here?
Last edited by Compman2002; Aug 5, 2019 at 12:52 AM. Reason: removing unwanted links
Old Aug 5, 2019 | 07:40 AM
gumbedamit's Avatar
gumbedamit
Originally Posted by Compman2002
Yeah I went with the Bluetooth Adapter from Amazon Automobil Pro Audio was a big help they even sent me a second box to test if the original box was faulty or not turns out it wasn't I am not too happy with the adapter though in that its a bit buggy, Pretty sure I can work through it though mainly having problems with alt and battery supply not being enough to handle the load I am giving them. So I am looking for a solution for a secondary battery placement the trunk is out of the question as it is housing my sub box and amp. Also looking for an upgrade to the alt any suggestion in here?
I use the same unit, what problems are you having with it and why do you need a 2nd battery? This adapter is for use with the HK system, what are you using it on?
Old Aug 5, 2019 | 09:04 PM
Compman2002
The problem I was having is wasn't powering on was not pairing up was a faulty box was replaced and now it's working
The reason for sencary battery is due to the amp draw on my system I removed my Hk amp replaced with an aftermarket planet audio amp 1200wtts pushing 2 - 12" 1000 watt subs from Bose the phantoms shallow mounts and it is drain battery when at idle but I think just an upgrade to my battery should do the trick and upgrading my connections to the amp mainly the ground I think I got it grounded to a weak ground point.
I ran the 2 missing lines from HU to the trunk to use with my amp kept the factory wiring to the factory speakers just straight wired them to bypass the factory amp connections
It was all abit of a pain while doing it all but I pressed on through it and got it done
Tito Febus
Navigation/Audio
Jul 5, 2023 05:43 AM
dcsmd007
28
Apr 23, 2012 07:48 PM
grradams
Aug 3, 2011 12:49 AM
JPG&R
Nov 15, 2010 10:24 AM
REHutch
19
Nov 29, 2009 07:30 AM
