Front sway bar bushings
Old Jul 29, 2019 | 11:07 AM
Scooter24's Avatar
Scooter24
Can the front sway bar bushings on a 2011 MCS be changed easily or does the subframe have to be dropped or lowered?
Old Jul 29, 2019 | 09:03 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes you either have to lower it in the back or remove it to replace the front sway bar bushings as you can't get the bolts out with it in the car and against the body.
But if you are going to do that much work go ahead and replace the front control arm bushings with some powerflex bushings as they are the most common to wear out every 50k.
https://www.waymotorworks.com/powerf...7-r58-r59.html
Old Jul 29, 2019 | 10:06 PM
Scooter24's Avatar
Scooter24
Yeah I'm doing control arm bushings tmrw. I have the special tool so I can do the control arm bushing without doing anything to the subframe. I just wasnt sure I was assuming the rear bolt on the sway bar bushing would hit the body but I was hoping i would be able to back it out enough while taking the front bolt out and be able to squeeze the bushing in and out.
Old Dec 30, 2019 | 11:14 AM
booyah93's Avatar
booyah93
I just dropped my subframe to do major work including ball joints and bushings.
Did your sway bar have large bulges near the metal lip that prevents their traveling inward?
wzabrouski
R60/R61 Stock Problems/Issues
Mar 23, 2016 04:53 PM
rmayf24
Oct 7, 2014 05:11 PM
Quitman Rhinehardt
Suspension
Dec 9, 2013 01:18 PM
Marwan
Suspension
Jul 4, 2011 08:43 AM
drftobin
Suspension
Jun 13, 2011 06:56 AM
