Water leaking from expansion tank cap?
Old Jul 19, 2019 | 02:52 PM
Mad Dog Tannen's Avatar
Mad Dog Tannen
I have a coolant leak and I am pretty sure it’s from the expansion tank cap.
Is there a little hole hole in the middle of the cap where coolant comes out?
I have filled the coolant a couple of times. No overheating.
Is it time to replace the cap?
The coolant is very dark colored, is this normal?
Old Jul 19, 2019 | 09:05 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
I assume R50 is pressurized like most cars. I would not worry about it as it is likely normal if you keep the cold coolant near the max level. My R53 will always have some overflow after driven on track. Change in altitude will affect when the mechanical pressure relief of the cap as is the coolant chemistry and concentration. I concentrated during high school physics and chemistry classes so I don't waste money buying new caps unless they are really bad.
Old Jul 19, 2019 | 09:40 PM
deepgrey's Avatar
deepgrey
The R50 tank actually isn't pressurized; it's a different design from the R53. That said, those pictures aren't of a first gen engine bay. R56 maybe?
Coolant change interval for first gen cars is every four years. I'm not sure about other model years.
Old Jul 20, 2019 | 06:20 AM
buzzsaw's Avatar
buzzsaw
I had the same problem with a metal tank.. I kept the coolant level at half when cold and had it leak out the cap twice before reducing the coolant level to just above the baffel or about just a tad above a quarter full. That was two years ago and no leaks since.
Old Jul 20, 2019 | 11:42 AM
Mad Dog Tannen
Thank you. That makes me feel better. It happened over about a 1000 miles of driving.
Old Jul 20, 2019 | 11:44 AM
Mad Dog Tannen
Thank you. I accidentally posted int he wrong section. It’s a NA R56. I will move it to the appropriate section.
Old Jul 20, 2019 | 11:45 AM
Mad Dog Tannen
Thank you. That makes me feel better lol
mini_racer
Apr 24, 2013 10:23 PM
Hip Check
Cooper (non S)
11
Jan 24, 2009 10:48 PM
bunce
Aug 15, 2008 07:59 PM
2Cool
May 3, 2004 03:44 PM
