Code 2065 + occasional "skips" under acceleration
Old Jun 28, 2019 | 03:53 PM
leftfield6's Avatar
leftfield6
2008 Clubman S with 93K on her. Have had the occasional miss or skip on acceleration, seems especially noticeable in 3rd or 4th. I've replaced all 4 plugs, and all 4 coils, they were due anyway, but this did not help. A few weeks ago, I got a Code 2065 on my P3 gauge. (love that thing) No CEL ever, though.
The code seems related to a fuel level sensor, but I have seen some posts that said it could be connected to to the HPFP. Of course, it is possible that the code and the skips are unrelated. I'm curious what the group-think here is. Is the HPFP issue always going to have the hard-to-start symptom? Cause i don't have that at all, she fires right up every time. Idle is not rock-steady, has about a 50 rpm wobble to it.
  • New OEM plugs
  • New coils
  • New air filter
  • all other maintenance 100% up to date
  • No other codes
Old Jun 29, 2019 | 07:20 PM
MiniToBe's Avatar
MiniToBe
mmmm..how about your timing chain?
sometimes the wrong spark plugs can effect the performance. not sure if this the case....Also, did you check the valve for carbon build-up?
Old Jun 30, 2019 | 06:47 AM
leftfield6's Avatar
leftfield6
Timing chain was done at 65k
soark plugs are correct ones, NGKs purchased at the MINI dealer
haven't had the carbon build up checked or cleaned. Probably need to do that.
Seems like none of those would cause the code 2065, though.
Old Jul 15, 2019 | 06:49 AM
leftfield6's Avatar
leftfield6
Bumping this up.
I cleared the 2065 code, it came back about 5 days later. It is not triggering a CEL. but my P3 gauge shows all codes, not just active ones.
I can't seem to find a correlation with fuel level, driving circumstances, etc. If it truly is just a tank level sensor (which is what the code actually says in every reference I have found), I don't see how that can be causing the pause in acceleration. But I have seen posts that have inferred this code is somehow connected to a possible pending HPFP failure.
Any one have any insights?
fixthedoor
R55 :: Clubman Talk (2008+)
Sep 14, 2016 07:03 AM
s0udwrench
Jul 6, 2015 03:55 PM
lttletimmy
Feb 22, 2008 02:54 PM
verbalassault
Feb 8, 2004 10:13 PM
kenchan
16
Oct 16, 2003 08:29 PM
