PLEASE HELP! How to exit CALIBRATION MODE in IHKA climate control module R53
Old Jun 19, 2019 | 09:07 PM
MyMistake's Avatar
MyMistake
Hello everyone,
I hope you can help with this issue since I'm baffled by it.
I tried IHKA diagnostics to try to fix foot air vent function but i ended up being stuck on loop on Mode 2 (calibration) even after switching the ignition off or unplugging the car battery for 5 minutes didn't work.
Now when starting the car it shows "CA" which indicates Calibration mode starting and I hear the vents opening and closing them just shows "FF 01" which indicate Solar Sensor error and I can't exit or change to other modes when pressing "OFF" or "+" instead I can't switch on the A/C at all.
What make things worse is that the car isn't mine and i was trying to help fixing the problem, secondly I don't have access spare Solar Sensor to replace and check if it solve the problem.
Thank you in advance.
I really appreciate it.
This is the thread where I followed the instruction to enter diagnostic mode, post #8
Showing FF
Showing error code 01 which indicates Solar Sensor
Old Jun 20, 2019 | 07:51 AM
gumbedamit's Avatar
gumbedamit
Originally Posted by MyMistake
Hello everyone,
Showing FF
Did you try disconnecting the battery and touching the -/+ terminals together?
Old Jun 20, 2019 | 08:37 AM
MyMistake's Avatar
MyMistake
Do you want me to do a face mask with sulfuric acid brother? Thanks though
Old Jun 20, 2019 | 09:19 AM
gumbedamit's Avatar
gumbedamit
In my message, "Listen Carefully" DISCONNECT THE BATTERY", touch the -/+ cables together to dissipate any residual current going to the ECU.
Old Jun 20, 2019 | 09:35 AM
MyMistake's Avatar
MyMistake
I already removed the battery for some time and didn't work and also removed the climate control module for some time and put back and nothing happened.
Are you sure about dissipating residual current? I never heard of that.
I'll give it a try
Thank you for your reply and sorry for reading your earlier reply wrongly
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Lick the terminals to make sure there is no residual charge left. There might still be a few strayed electrons in the ECU.
Old Jun 20, 2019 | 09:43 AM
MyMistake's Avatar
MyMistake
Residual current bruhh! What are you laughing at 😂
Old Jun 20, 2019 | 10:09 AM
gumbedamit's Avatar
gumbedamit
I'll give it a try
I thought disconnecting the battery might get the ECU out of the diagnostic loop, didn't know that you've already done that. There is no voodoo to touching the cables together, it just discharges the systems.
Old Jun 23, 2019 | 04:41 PM
Blue R50's Avatar
Blue R50
You might want to try disconnecting them for a few hours or overnight. Otherwise, I have no experience with this. I do know that a few days of disconnect cleared all of my engine management codes that would not clear with a simple code reader.
Old Dec 23, 2022 | 11:12 AM
NegativeNick's Avatar
NegativeNick
Did you have any success turning this off? Im currently having trouble with the same thing and theres no answers online on how to fix it.
Old Jan 6, 2023 | 02:40 PM
Dougster7's Avatar
Dougster7
I’ve the same issue, posted today on another thread, search my only post in case you’ve not seen it and anything helps you out. The more the merrier….surely 🙏
Old Jan 11, 2023 | 12:22 PM
ssoliman's Avatar
ssoliman
See my thread “heat not working” or something like that
note you might find a used control panel on all mag auto parts…
Old Jan 11, 2023 | 01:36 PM
Dougster7's Avatar
Dougster7
hey, thanks for adding to this thread. I’ve read your thread but still stuck on test, already tried a 2nd hand unit which didn’t read the fault codes until I carried out the test function again and now it’s the same as the old unit. All pointing to the fault remaining in the system and only way out of it is to fix the fault which is all pointing to the solar sensor
Old Mar 8, 2023 | 10:28 AM
Dougster7's Avatar
Dougster7
Sorted ✅
Had the above issue for a few months so booked it into Mini to change the solar sensor as the wiring felt stuck in the dash, as if it would snap if pulled any harder. Been for various runs in it over the past few months all very cold, this morning I started it up and the panel didn’t have the FF01 code for a change, it displayed the temp setting so I left it to warm up. 10 mins later the cab was roasting! Heater working again absolutely fine so I took it to Mini anyway to have a check over. They stuck it on the diagnostics and it said the mixer flap had been stuck but working fine now. No charge either as they said the lads all enjoyed seeing the old car in the workshop! Strange the fault code given was FF01 when the solar sensor was working all along. Obviously the car didn’t like the sound of going to the doctor 😂
Lobotomy
May 16, 2020 01:38 AM
Sailorlite
Jul 25, 2016 02:27 PM
fishbulb
Jun 19, 2009 07:42 PM
