Replaced thermostat, still have code PO128
Old Jun 17, 2019 | 07:05 PM
ammodave's Avatar
ammodave
I recently replaced my thermostat due to an overheating problem. The overheat problem went away but I still have the yellow engine light. Do I need a code reader to make the code go away?
Old Jun 18, 2019 | 07:16 AM
mkov608's Avatar
mkov608
At a minimum you need to connect a scanner to the vehicle and see if a DTC is still locked in the DME memory. If it is, you'll need to clear it.
http://www.foxwellmall.com/
Old Jun 18, 2019 | 09:24 AM
Yupetc's Avatar
Yupetc
Be careful with that temp sensor plug, too. If you can get a realtime readout on that temperature, that's the best way to see what's wrong.
I had gone through 3 sensors on one MCS before, all the while, it's the sensor plug that has an issue, the prong got pushed off and couldn't be in contact with the sensor itself.
Old Jun 18, 2019 | 10:51 PM
Gabe3's Avatar
Gabe3
I have a $10 bluetooth code reader from amazon I use to clear codes with the torque lite app
ammodave
Jun 8, 2019 05:42 AM
jglover
Aug 11, 2018 02:06 PM
virexdeus
Jan 7, 2018 07:50 PM
dnelson
Feb 6, 2014 05:41 AM
SPRINTCARS
Jul 15, 2013 10:44 PM
